13/14 Rear.. Casting date?
Retro54
First Name: Andrew
Last Name: Blaydon
Post by Retro54 » Fri Jun 18, 2021 7:50 pm
Was working on the rear axle today and dad and I were wondering if the casting numbers on the one half of the shell translate to a casting date. 7 - M - 14 shows clearly on one half above the part #. Just curious if July 1914 would be a translation, or is the set of numbers and letter have no significance.
Ideas or insults welcome :D
Andy
The half with those casting numbers
The other housing.
The other housing.
MTFCA Number: 121
MTFCI Number: 16310
Re: 13/14 Rear.. Casting date?
Post by Original Smith » Sat Jun 19, 2021 11:17 am
Don't use those lock washers!
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Sat Jun 19, 2021 3:07 pm
The stud type bearing sleeve retainer studs have holes for safety wire. no lock washers untill later with hex head bolts.
Casting date likely. 7/13/14. Dont assume it helps date the assembly of your T. My early '15 WIDE TRACK roadster has a 13 rear end with a 2 piece D/S. Due to its rarity & low production, I believe it to have been factory installed, absent of other information. "Last in first out inventory." Wide tracks discontinued '15 or '16.
Retro54
First Name: Andrew
Last Name: Blaydon
Post by Retro54 » Sat Jun 19, 2021 6:16 pm
Thank you Speedy. Understood on car assembly. Just was curious about the axle only. Was thinking it might be a casting date and know that there are some great and knowledgeable people on here whom are willing to lend their opinions.
Andy
