Help to identify a tool
otrcman
First Name: Dick
Last Name: Fischer
Post by otrcman » Sat Jun 19, 2021 7:05 pm
I have no idea what this device is. It was in my father's garage. Dad was a T guy, so I'm hoping it is some sort of T item that someone can identify. The overall length is about 10". It does no fold out straight. The two pics show the full open and full closed positions.
Thanks in advance for looking.
Mystery tool 3.jpg (59.56 KiB) Viewed 1114 times
Mystery tool 1.jpg (40.75 KiB) Viewed 1114 times
Mystery tool 2.jpg (35.95 KiB) Viewed 1114 times
Last Name: Hatch
MTFCA Number: 49974
Re: Help to identify a tool
Post by Dan Hatch » Sat Jun 19, 2021 7:11 pm
Piston ring groove cleaner.
otrcman
First Name: Dick
Last Name: Fischer
Post by otrcman » Sat Jun 19, 2021 7:20 pm
Thanks for the fast I.D. Dan. Do you know if it's meant specifically for a Model T, or is it a generic ?
Dick
MTFCA Number: 51486
Post by TXGOAT2 » Sat Jun 19, 2021 11:05 pm
It's a mechanic's tool. (Lisle?) The spoke like device has a selection of scraper bits for use with various types of pistons. You loosen the knob and turn the spoked wheel so that the correct bit is in position to use. A stock Model T would use a bit designed for a 1/4" ring groove. The tool is to be used carefully, taking out only carbon, and no metal.
