Reverse problem
Posted: Sun Jun 20, 2021 6:37 am
by geoffrey mark
Fitted new set of band in my 23 touring , only problem is when I step on the reverse pedal it goes back a bit then seams to bind up and stall , what could be the problem ?
Re: Reverse problem
Posted: Sun Jun 20, 2021 8:45 am
by FundyTides
Low band too tight?
Re: Reverse problem
Posted: Sun Jun 20, 2021 11:05 am
by Norman Kling
Is it possible the reverse band is hanging over the low drum?
Re: Reverse problem
Posted: Sun Jun 20, 2021 12:28 pm
by speedytinc
This t was a running unit with NO OTHER recent other work??
These are not kevlars with a high spot loop in the lining? Bands are not over tight? When you run it, NO extra tripple gear noise?( good clue for over tight bands)
You are not unknowingly hitting 2 pedals at he same time? Can you see your feet & pedals during operation? Extra large shoe size?
Not being silly here. I had a buddy that went thru 2 sets of tripple gears by unknowingly engaging 2 bands(low & rev)on a regular basis untill I observed it for myself. He was totally unaware. I think he solved the problem with a reverse pedal extension & the awareness.
Re: Reverse problem
Posted: Sun Jun 20, 2021 2:45 pm
by John kuehn
A reverse pedal extension helps a lot to get a clean reverse! If your a big footed guy it’s almost a necessity to have one! And yes it does keep you from engaging the clutch and reverse at the same time. I wear size 13 and guys with bigger feet that that would have a tough time it seems to me.
Re: Reverse problem
Posted: Sun Jun 20, 2021 9:11 pm
by Norman Kling
Another thing is to engage neutral with the parking brake lever in the neutral position. Then use the left foot for reverse, of course, being careful not to push the clutch while using the reverse. That also frees the right foot for use with the foot brake.
Re: Reverse problem
Posted: Mon Jun 21, 2021 4:03 am
by Alan Long
The above is the exact reason I drive bare feet! I use rubber covers on my pedals for obvious reasons....
Alan in Western Australia
Re: Reverse problem
Posted: Mon Jun 21, 2021 12:01 pm
by jiminbartow
In 1926, Ford addressed the small pedal problem by building pedal extensions onto the outer clutch and brake pedals, but could do nothing about improving access to the center reverse pedal. Being on the outside, I can see where pedal extensions would help on the brake and clutch pedals on pre-1926 T’s, but being in the middle, with only a finite space between the brake and clutch pedals, what sort of pedal extension could be installed on the reverse pedal provide more room for big feet other than bending the brake and clutch pedals outward to increase the space? At 6’ 3” and 230lbs., I have size 14 shoes and must either tilt my foot and use the outer right edge of my shoe or use the point of my shoe to depress the reverse pedal. I don’t go barefoot, ever. Jim Patrick
- 99D0A1CB-EA76-4216-8E20-76084C069E50.jpeg (72.23 KiB) Viewed 4004 times
Re: Reverse problem
Posted: Mon Jun 21, 2021 12:17 pm
by geoffrey mark
So no big feet , that's not my problem ! Had the car out today reversed no problem when just started , after a run when hot only backs up about 4 yards then seams to bind up and stop , was watching where my foot was definately only reverse pressed ! Thanks
Re: Reverse problem
Posted: Mon Jun 21, 2021 12:45 pm
by speedytinc
speedytinc wrote: ↑Sun Jun 20, 2021 12:28 pm
Q1 This t was a running unit with NO OTHER recent other work??
Q2 These are not kevlars with a high spot loop in the lining? Q3 Did you install kevlars thru the inspection cover? Q4 Bands are not over tight? Q5 When you run it, NO extra tripple gear noise?( good clue for over tight bands)
Q6 Did you have your parking brake in neutral for that last test?
When hot bushings binding.
Q1 This t was a running unit with NO OTHER previous recent other work??
try a bunch of low pedal, see if the tripple gear bushings start to bind. Make sure your oil level is full.
Re: Reverse problem
Posted: Mon Jun 21, 2021 6:56 pm
by Scott_Conger
I hate guessing games, and this is one of them...that said, I'll break my rule of not jumping in with zero knowledge of the car and suggest that perhaps you have a broken spring on your parking break shoes and have lined shoes (or a lining has come unbonded). If the car backed up when cool and then played games with you later, the lining may have simply gotten hot enough to start grabbing when going backwards like a self-energizing shoe.
I'd jack up the rear end...look for excessive play in the axles to eliminate pinion binding and then try rotating wheels backwards when this "no reversing" manifests itself. This will take the transmission and clutch out of the mechanical loop and you will be testing fits and performance within ONLY the rear end.
Re: Reverse problem
Posted: Mon Jun 21, 2021 7:28 pm
by Mark Gregush
On Scott.s note, I was wondering if it had outside brakes and when backing up was self energizing.
Re: Reverse problem
Posted: Tue Jun 22, 2021 10:13 am
by Adam
Fractured driven gear sleeve.
Re: Reverse problem
Posted: Tue Jun 22, 2021 1:05 pm
by got10carz
I keep wondering if it has something to do with removable band ears.
Re: Reverse problem
Posted: Wed Jun 23, 2021 12:31 pm
by geoffrey mark
No external brakes , new bands were fitted after removing the hogs head , to repair a bad oil leak , I never drove the car due to a bad oil leak . Will report back after my next run out !
Re: Reverse problem
Posted: Wed Jun 23, 2021 1:17 pm
by speedytinc
You have not answered my 6 questions.
Re: Reverse problem
Posted: Thu Jun 24, 2021 8:50 pm
by paddy1998
John kuehn wrote: ↑Sun Jun 20, 2021 2:45 pm
As a Bigfoot I needed the reverse extender and I still have to turn my foot sideways to be sure not to push other pedals. And I have to look at it while I'm starting in reverse to be certain.
We all have our crosses to bear.
