Wood Felloe Wheel Disassembly
ryanf1023
First Name: Ryan
Last Name: Fenrich
* REQUIRED* Type and Year of Model Ts owned: Speedster Project
Post by ryanf1023 » Mon Jun 21, 2021 11:57 am
I am taking apart my original wheels. The spokes and felloes are too far gone to reuse. However, the (non demountable clinchers) rims are quite usable with sandblasting and perhaps a bit more work. I have three of the four hubs out (last one is real tight). I'm not sure how to further disassemble. I drilled out the bolts holding the hardware out, but it is clear there is another fastener somewhere. Can someone please explain how to remove the rims off of wooden felloe wheels?
MTFCA Number: 52564
Re: Wood Felloe Wheel Disassembly
Post by Mark Gregush » Mon Jun 21, 2021 12:12 pm
You have to take the rivets out, there should be 4. Are you sending the wheels out for rebuild? Not an average Joe home job to rebuild the wood felloe wheels.
1920 Dodge touring
ryanf1023
First Name: Ryan
Last Name: Fenrich
Post by ryanf1023 » Mon Jun 21, 2021 12:53 pm
Yes, they will be professionally rebuilt.
Are there four rivets in addition to the hardware holding the felloes down? Or are those the rivets you are referring to?
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Mon Jun 21, 2021 1:18 pm
The only rivets are the ones holding the felloe to the rim. There are two at each joint plate. Some wheels have a total of six, and some have eight.If you remove those and press the hub out of the spokes the rest of the disassembly should not be difficult.
MTFCA Number: 24868
Post by Jerry VanOoteghem » Mon Jun 21, 2021 2:51 pm
Sometimes, in addition to the original rivets, people add wood screws as a band-aid for loose felloes. You might look for those as well.
Kerry
Last Name: van Ekeren
Post by Kerry » Mon Jun 21, 2021 6:40 pm
Big hammer.
Post by Allan » Mon Jun 21, 2021 8:04 pm
Just saw the spoke through. Then all is free to let a hammer do the work.
ryanf1023
First Name: Ryan
Last Name: Fenrich
Post by ryanf1023 » Tue Jun 22, 2021 3:06 am
Thank you everyone. I managed to solve my issue.
There was an additional rivet through the each half felloe and one spoke on each end. Perhaps evidence of an early repair. I know now what to look for on my other wheels and should be able to do the same disassembly relatively smoothly.
