Generator f Front Bearing
Topic author - Posts: 123
- First Name: Brendan
- Last Name: Doughty
- * REQUIRED* Type and Year of Model Ts owned: 16 , 21, 24, Touring , 24 Roadster, 26 Speedster
- MTFCA Number: 15143
I have taken two generators apart lately that have two bearings in front. The rear bearing acts as a spacer as the shaft shoulder is set back. What's the deal.
- MTFCA Number: 52564
Re: Generator f Front Bearing
You can add up to 5 photos per post, so you may want to combine all into one and if more then 5, add as a reply to keep all in same string. If that brush plate came out of the same generator, maybe post the whole unit showing the case and end pieces.
1920 Dodge touring
1920 Dodge touring
No Not out of the same unit.
- MTFCA Number: 14383
I have rebuit a couple hundred generators. Never seen this.
SWAG: Say Q/C ends up with a batch of scrap armatures where the shaft is machined too far in.(out of tolerence) They rework the shaft using a 2nd bearing as a spacer. Parts made usable. That 2nd bearing could serve no other purpose.
- First Name: William
- Last Name: May
Could that be an example of one of the very early Ford Generators? The F.A. Liberty generator, (or whatever it was) before they went to the standard Ford pattern device?
