Hi,
can someone give me the precise measurements of the front and rear original Ford spring cushions and also for the front and rear backrest springs. What I need is the outer measurments, as I have problems to make the new Snyders upholstery kit parts fit, especially on the front cushion.
Seat spring size
- Last Name: van Ekeren
Re: Seat spring size
I'm sure to get an answer for you question, one would need to know year and body style.
Topic author - Posts: 8
- First Name: Magnus
- Last Name: Wiberg
- * REQUIRED* Type and Year of Model Ts owned: 1919 TT Truck, 1923 Touring, 1919 Touring , 1922 Pic up
You nare absolutely right! Of course, I need to give year and body style with my question! I just forgot!!
The Model T in my question is a 1919 US built Touring car.
Magnus
Magnus
- MTFCA Number: 52564
I was given the front seat section of a 1919 or 1920 touring. It looked like the upholstery had never been off. The back cushion was hung off the tack rail, there was a piece of upholstery card stock between it and the body, no other support. The bottom cushion is; 17-1/2" X 36-3/4" (44.45 X 93.345 CM). If you need the front seat back rest, I can get that later.
1920 Dodge touring
1920 Dodge touring
