Interesting T head
Topic author - Posts: 11
- First Name: Chris
- Last Name: Otto
- * REQUIRED* Type and Year of Model Ts owned: 1921
Interesting T head
I received a few questions about the head I am running. I too do not know much about it. I have attached a few links to the information I have obtained on it. As you can see in the pictures, I had to perform a lot of work to get it into working condition. Leveled both the top surface and shaved the decking surface. Where the head bolts go through, we milled them all level. We cleaned up the combustion chambers as well. I did not purchase it from any member on here and do not know the people in the links personally.
http://www.mtfca.com/discus/messages/17 ... 1323235112
http://www.mtfca.com/discus/messages/25 ... 1352236774
http://www.mtfca.com/discus/messages/17 ... 1318551201
http://www.mtfca.com/discus/messages/33 ... 1375923631
http://www.mtfca.com/discus/messages/33 ... 1386738108
- First Name: Antonio
- Last Name: Piery
- * REQUIRED* Type and Year of Model Ts owned: some very old cars
Re: Interesting T head
That head looks like the one off a Model T engine for a airplane, but with a water jacket.
- First Name: Duane
- Last Name: Cooley
Cool head!
I've seen one before here but don't recall where.
- First Name: Chris
- Last Name: Otto
Just received this..........
- Last Name: Hanlon
This brings up the old question...If Harley Davidson made an airplane, would you fly in it ??Tea_time_racer wrote: ↑Thu Jan 10, 2019 12:42 amThat head looks like the one off a Model T engine for a airplane, but with a water jacket. ModelTAirplane.JPG
I think I have to pass on riding in an airplane powered by a T engine !
- Last Name: Bennington
- * REQUIRED* Type and Year of Model Ts owned: 1921 Roadster
I always see Model T engines for airplane use crop up on the forum, but I’ve never seen an answer to the obvious question to follow: Did anyone manage to make a craft fly with one?
The forum's resident Millennial.
- Last Name: Piery
I think it was Pietenpol company that put a Model T engine and later a Model A engine in a airplane. I have seen a Model A powered plane fly, but without the redundancy on the ignition and with other faults that we are all aware on these engines I would not do it. Juts because it can be done don't make it right.
- First Name: Jerome
- Last Name: Hoffman
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 Roadster, 1923 Speedster, 1923 Racer, 1921 TT Wood Cab
Cris Essaguards(sp) plane in the MTFCA museum in Richmond is equipped with an aluminum head and uses two spark plugs with two ignition sources.
model_t@swbell.net
Projects: 1916 Speedster - Dec 15', 1921 TT Wood Cab and Bed, 1923 Racer ( My dad's), 1923 Speedster (started in HS)
1924 Roadster - Dec 23' (eBay) and 1924 Touring - June 24' ( Dad's Car been in the family since 1948)
