TiltLok Steering Wheel
Posted: Wed Jul 07, 2021 4:03 pm
by Duckwing
Re: TiltLok Steering Wheel
Posted: Wed Jul 07, 2021 7:10 pm
by GG Gregory
What type car does it fit ? I see it fits a splined shaft.
Posted: Wed Jul 07, 2021 7:41 pm
by Duckwing
I have no idea what it fits. I'm still trying to verify how it works. I've squirted WD-40 and PB-Blaster around the hub but have yet to get it to rotate (assuming that's what it should do).
Posted: Wed Jul 07, 2021 8:19 pm
It is unlikely to ever rotate. It appears to be like any number of "T wheel locks where the pin engages a groove in the steering shaft to hold the wheel on, or in place and releasing the pin and lifting the wheel up (and re engaging the pin into another groove) locks the wheel off of the spline and allows it to ONLY spin and not steer the car. I do not know what this particular application fits but suspect that you are missing a lower portion which screwed onto the top of the steering column.
Posted: Wed Jul 07, 2021 9:17 pm
by Dave Sullivan
Might be early Model A.. Dave in Bellingham
Posted: Wed Jul 07, 2021 11:00 pm
by Duckwing
This is a photo from the bottom side. Does the hub slide up and down in the wheel vs rotating? I admit I’ve never seen a steering wheel like this so having trouble visualizing the action description provided.
- Try
- A68180BE-F137-4139-9F9C-04051ADA2B0A.jpeg (29.19 KiB) Viewed 2467 times
Posted: Thu Jul 08, 2021 10:28 am
Looking again more closely, there clearly is a snap-ring retaining ring in it and you may very well have figured out what it is supposed to do, and how. As for fixing it, loosening it, whatever, personally I'd leave that to the new owner.
Posted: Thu Jul 08, 2021 3:56 pm
by Duckwing
Think not messing with it is a good plan. My investigations in the past have not worked out well.
