Drive train noise... oPinions?
Posted: Sun Jul 11, 2021 3:28 am
Im on the Spokane tour (it's beautiful here) but I'm dealing with a noisy rear end. I promise it's nothing I ate....
A little history.
I have 1921 Touring, the Ruckstell was rebuilt 3 yrs ago with all the good stuff. New Pinion gear installed then and the ring gear was perfect. We set the r&p lash per standard specs. After the rebuild, there was a MAJOR NOISEY R&P but after 1000 or so miles, it settled down to a nice, acceptable whir. No noisier then than any of your cars.
Fast forward to 4 months ago, and I had Micky and his partner down in Bakersfield build me a Laycock drivetrain - actually it took him over a year (but whose counting) and I finally installed it 4 months ago. Their work is regarded as the best in the business and the end result is a literal work of art. It works great and shifts flawlessly. I installed it with the same spool and fun projects bearing I had with the original drive shaft. I also used the same number of paper gasket spacers between the spool and ruckstell housing as I had previously.
However, now there is a new whirring/grinding noise coming from the drivetrain I can't identify. It ONLY happens on acceleration under load. At cruising speed, the noise is gone. The pitch/frequency of the noise under acceleration is the same no matter what gear I'm in, low Ruckstell, hi Ford, over drive, direct drive. To me, this eliminates the entire input section to the Laycock. So it has to be either the output of the Laycock or the ring & pinion. After several hundred miles, the noise hasn't really changed or gotten worse, its persistent, again only under load and always the same pitch regardless of what gear I'm in . This leads me to think it's the R&P again, just manifested in a different way as the sound is different from the first time I rebuilt the Ruckstell and rear end.
If it Is the r&p, is it too tight or too loose? I suppose it could be coming from the Laycock, but I'm not familiar with the inner workings other than I know there are several bearings of different types in that unit.
These noises are so hard to diagnose as they travel thru the drivetrain and resonate in odd ways making you think it's coming from one area when in reality it's coming from a totally different place.
Anyway, thoughts and educated opinions welcome.
AdminJeff
Ps, yes, I finally finished my move to Idaho a month ago (what a nightmare, I can't find half my crap) and I'm slowly getting the shop back together. I'll be spinning up the starter/generator rebuilding biz again once things settle down in a few months. Thanks for all the inquiries, but this move has been brutal. The shop move alone was over 30,000 pounds.
A little history.
AdminJeff
