How to replace cowl on a 1927 Touring
Topic author - Posts: 221
- First Name: Bruce
- Last Name: Klawiter
I placed an add for a cowl and some of the questions I am getting make me think that this may not be as easy as I thought. I appeared to me I could just grind the rivets off and unbolt a few things and the cowl should come off, is this correct or is there a lot more to it. The car is completely assembled.
- First Name: Ken
- Last Name: Buhler
- MTFCA Number: 49471
- Board Member Since: 2012
Re: How to repalce cowl on a 1927 Touring
Be patient, I will send photos that will help you with your decision.
Work honestly
Stay true to your word
Get the job done right
- First Name: Ken
- Last Name: Buhler
Bruce,
I apologize for the duration. I have created a file with many photos of the cowl restore procedure and am looking for guidance to post so many photos in order with commentary.
Ken Buhler
Ken Buhler
Work honestly
- Last Name: Zibell
- MTFCA Number: 30265
- MTFCI Number: 24046
You may need to make several posts with 3 or so photos in each post.Ken Buhler wrote: ↑Mon Aug 02, 2021 12:51 amBruce,
Ken Buhler
1926 Tudor
- First Name: Bruce
Ken Buhler, did you ever figure out how to post the pictures? I would really like to see what you did.
