Installing Rajo oil level indicator
Posted: Thu Jul 15, 2021 7:46 am
by Nunsio1
I installed the Rajo oil indicator from T. Mosher, put in 4 qts of fresh oil - no movement of the indicator, how much xtra oil needs to be added? Thanks
Re: Installing Rajo oil level indicator
Posted: Thu Jul 15, 2021 9:25 am
by Dallas Landers
I bet if you contact Tim , he can answer your questions. 4 qts should be full. Its a little over full on mine.
Posted: Thu Jul 15, 2021 9:26 am
by perry kete
Perhaps there is air trapped in the system. You may have to bleed it out.
Posted: Thu Jul 15, 2021 9:58 am
by NealW
When I installed mine, I left the upper petcock open and let the excess bleed off.
Posted: Thu Jul 15, 2021 1:52 pm
by John Codman
I have found that four quarts fills mine right to the top petcock. I have also found that engine oil leakage and consumption is virtually zero. I don't even check the oil level between changes (it leaks enough rear axle oil to make up for it).
BYW: Does anyone know where I can purchase 600W gear oil? None of the local auto parts stores seem to have it, and I am not paying $12.50 to ship a quart of oil.
Posted: Thu Jul 15, 2021 5:36 pm
by jsaylor
Nunsio1 wrote: ↑Thu Jul 15, 2021 7:46 am
Make sure you installed it in the lower crank case hole, not the upper.
Posted: Sat Jul 17, 2021 10:44 am
by dmdeaton
Is the float in a bind? May need tweaking
Posted: Sat Jul 17, 2021 11:49 am
dmdeaton wrote: ↑Sat Jul 17, 2021 10:44 am
or lubricating
Posted: Sat Jul 17, 2021 10:25 pm
by Dropacent
I contacted John, and all is well.
Posted: Sun Jul 18, 2021 12:00 pm
Soooo what was the problem?
Posted: Sun Jul 18, 2021 12:26 pm
by Nunsio1
The problem with the Rajo oil indicator was just air trapped, everything working fine... nice quality accessory. Thanks John
Posted: Mon Jul 19, 2021 6:42 pm
by NU2theT
I always get "hey what is that" when I lift the right hood side and guys are checking out the engine. I love it and the day/night tank guage as well.
Posted: Mon Jul 19, 2021 11:21 pm
by Model T Ron
Never did see a Ranjo oil indictor but someone installed a dip stick on my 1915 Touring car. It goes to the lower engine oil plug and comes out at the top of the firewall on the right side under the hood. Works great but it has a modern T plastic handle that I want to chance for a simple metal loop to pull on.
