Universal grease
Posted: Sun Jul 25, 2021 12:58 pm
by mike zahorik
In the past I have always used wheel bearing grease in the ball cap/ universal joint. Recently, at a farm supply store I saw some NGLI 00 grease, that is used in some farm gearing applications. This grease has a low viscosity. I figured that regular wheel bearing grease in the ball cap will be spun off the universal and stick to the sides of the ball cap. I understand that the clearance in the ball cap is small and there is some motor oil leakage into the ball cap, so maybe this is not a real problem, But a low viscosity grease will slump in the bottom of the ball cap when the the universal stops spinning and re-coat the universal. Maybe some draw backs to the low viscosity grease is that it may thin with motor oil leakage and could leak out of the ball cap. Looking for opinions, Thanks, Mike
Re: Universal grease
Posted: Sun Jul 25, 2021 1:37 pm
mike zahorik wrote: ↑Sun Jul 25, 2021 12:58 pm
The U-joint ball is supposed to be packed(full)
Posted: Sun Jul 25, 2021 3:27 pm
Did a little research about NLGI numbers. Also it would seam that CV joints are similar to T's ball cap & u-joint design so why not that type of grease?
The NLGI consistency number, sometimes referred to as NLGI grade, refers to the relative hardness of a grease used for lubrication as specified by the institute's standards.
https://petroleumservicecompany.com/greases/
NLGI 0 grade grease is a very soft grease about the consistency of brown mustard.
NLGI 00 grade grease has a semi-fluid consistency similar to applesauce.
NLGI 000 grade grease has a semi-fluid consistency similar to cooking oil.
NLGI 1 grade grease has a semi-fluid consistency similar to tomato paste.
NLGI 2 grade grease has a consistency similar to peanut butter.
Interesting comments from
https://smazka.ru/eng/news/novosti-komp ... lya-shrus/
STABILITY - squeeze small quantity of grease on sheet of paper. If there is no any oily spot on paper around grease within one minute, grease is quite stable.
BODY - Good grease for cv-joints should have 2/3 NLGI consistency number.
ADHESION - In simple words, adhesion is stickiness. Squeeze small quantity of grease on the surface and press down with your finger. It should stretch like bubble gum. It will guarantee that the grease will not leak from cv-joint and will not be washed out from the unit by water even if the axle boot is broken
So sounds like NLGI 00 is too thin and will leak around the ball cap, requiring more refills. I like the ADHESION explanation NLGI 2 sounds appropriate
Posted: Sun Jul 25, 2021 5:44 pm
I use Wheel Bearing grease. Other thick grease will work but you need to pack it full because there is no seal on the ball cap and the more grease you have there will prevent engine oil from dripping out or running down the drive shaft to the differential. Don't use any grease containing graphite because if some of it works into the transmission, graphite is an electrical conductor and could interfere with the magneto.
Posted: Sun Jul 25, 2021 6:06 pm
by TWrenn
Like Speedytinc saod...I pack it FULL when I have the engine or rear end out, and I KEEP it that way every oil change via use of a zerk equipped grease cup. (At least try to). Yeh I know, not "authentic!" Takes about 30 pumps with the grease cartridge gun.
Posted: Mon Jul 26, 2021 7:00 am
by bobt
I use John Deere corn head grease. bobt
Posted: Mon Jul 26, 2021 12:33 pm
by mike zahorik
Thanks for the advise. I decided to 'stick' with the wheel bearing grease. First it is common and if I need some on the road, everywhere will have some. AND since I have not heard of any problems with wheel bearing grease (most everyone uses it) it must work. Thanks again. Mike
Posted: Mon Jul 26, 2021 2:05 pm
by jiminbartow
Good decision. To reiterate… If you use a low viscosity grease, it will lubricate better in the short term but will leak out of the ball much faster than the high viscosity Valvoline red wheel grease that I use. As everyone says. Pack the ball full so the grease cannot be slung out and will also prevent the crankcase oil from leaking out through the rear. Jim Patrick
Posted: Mon Jul 26, 2021 2:06 pm
by DickC
Have you heard of a product called "portable grease"? A friend who has some of the largest cranes made uses it on his cranes and in the rear ends of his collector cars. His collector cars go from T's to Stutz. I am using it in the rear end of all my T's. Better than "600" think. Maybe I will use it in the ball cap.
Posted: Mon Jul 26, 2021 2:17 pm
DickC wrote: ↑Mon Jul 26, 2021 2:06 pm
I dont know this product, but be aware the ball joint isnt sealed. Liquid will seep out around the flange. In fact, as one fills the cavity, when grease starts oozing around the flange, one knows its full.
Posted: Tue Jul 27, 2021 8:18 am
by Loftfield
NLGI 00 was originally called Non-Fluid Oil. It was recommended for most lube places on early Buicks, a car with more sophisticated engineering than Fords (I own both). NLGI 00 is a Non-Newtonian Fluid, meaning it "flows" under pressure or vibration, but returns to more or less solidity at rest. Because it was recommended for my early Buicks, I use it a lot, so far with no adverse effects noted. In the universal joint setting, there is a tendency for the spinning u-joint to throw the grease against the side of the housing, and if the grease does not then flow it stays on the side, not lubricating anything, full ball or not. The standard thought was that small amounts of engine oil leaking into the ball would keep it all going. I am now trying NLGI 00 in the u-joint, will see if it leaks out or not. So far there was no significant leakage after driving 400 miles in the New Philadelphia tour. Similarly I am using NLGI 00 in the differential, also much less leakage than previously, and no bad signals after the recent tour. For those who care, this product can be had from at least one restoration supply house at $56 a quart, or from Tractor Supply Company as Cotton Picker Spindle Grease (in the farm equipment section, NOT the oils and lube section) for a little over $5.00 a quart.
Posted: Tue Jul 27, 2021 11:36 pm
by jiminbartow
If the ball is packed full of thick bearing grease, there is no space for the slung grease to go, so it remains inside the spinning cage of the universal joint, thereby providing never ending lubrication. Only if you partially fill the ball will there be space enough for the grease to be slung out of the cage to remain against the inside wall of the ball. That is why it is important to keep the ball topped off so it remains full. Jim Patrick
