Early top fasteners
Topic author - Posts: 3384
- Last Name: Morsher
Early top fasteners
Thanks to keith, I’ve corrected my post. Here are some samples, I’m sure there are others. The very early T and pre-T used similar fasteners to the Murphy, but different. I think appropriate for very early T, and certainly pre-T autos. I don’t have an example of a Murphy brand to show, but are the same and interchangeable with the Common Sense brand. Then, Lift-the-Dot , which is a brand and encompasses other fasteners, also called lift-the-dot, and finally post snaps. These also likely have a name, don’t know what it is, but generally these last two are common in the model A Ford and that era.
- First Name: Keith
- Last Name: Townsend
- MTFCA Number: 14778
- MTFCI Number: 16305
Re: Early top fasteners
Those on the left are Burco Fasteners.
Thanks Keith!
- First Name: Keith
Top right oval base Murphy fastener. '12 - ?
Middle left original Murphy Fastener
Middle right reproduction double height Murphy fastener.
Bottom left original Murphy fastener.
Bottom right reproduction Murphy fasteners have screw head on the underside.
Keith
- MTFCA Number: 30701
- MTFCI Number: 24033
My '11 Torpedo has fasteners similar to the Murphys pictured above, except they say "dot" on them. Not to be confused with "lift-a-dot".
- First Name: Keith
Tim,
Like this?
Like this?
I’ll post some great stuff I stole off the interweb. Keep in mind, different folks have different names for some of this stuff, so be careful. There were regional differences, nicknames, etc, it’s a good resource to identify a lot of neat hardware used on our old cars.
[/attachment]
- MTFCA Number: 14972
- MTFCI Number: 15411
Well, that's "educational" as all hell !!! Thanks Tim !
Now that Steve and the other Tim bounced my first response Keith I'll try again!
The answer to your question is "yup".
And also, I have no idea if they are "original T" or not. Maybe the "other Tim", my good friend i also call Tim I, will have an idea!
Tim II
- MTFCA Number: 1219
What a nice collection of information. Here are a couple variations on the Murphy as well as one with an anchor symbol on it. I'm sure there were a lot of companies making their own version.
ThanksRich
- First Name: Keith
All of these fasteners were on one unrestored original 1911 touring:
- First Name: Keith
These too.
I'm sure these was a bin of single height, and a bin on double height with all brands mixed in together...
- First Name: Keith
Here is a nifty little set of replacement Anchor fasteners I picked up a while back:
Keith
Keith
- First Name: Keith
Early Anchor fasteners had an A. I'm not sure if the Anchor picture came later.
The Murphy Fastener was patented May 7, 1907: The Bourque Fastener was patented Jan 1919:
If you so a google search you can read all about the 1914 lawsuit between Murphy and the Metal Stamping Company...
Keith
At some point Murphy and Bruco joined:The Murphy Fastener was patented May 7, 1907: The Bourque Fastener was patented Jan 1919:
Keith
- First Name: Keith
Oh and the "glove fasteners" are Anzo fasteners. They are the predecessor to what we call today a "snap".
The stud of the Anzo passes through a hole in the side curtain and the top flap "snaps" onto the stud, sandwiching the side curtain in place.
- First Name: MICHAEL
- Last Name: FRANCIS
- MTFCA Number: 411
- MTFCI Number: 171
Thank you for posting. I've been collecting so many of those fasteners and now I know the REAL names for the ones I didn't already know.
- MTFCA Number: 121
- MTFCI Number: 16310
I believe that fastener with the DOT on it is a newly made variety. I've never seen an old stock common sense fastener with a flat top. I have hundreds of original common sense fasteners to prove it.
- MTFCA Number: 411
- MTFCI Number: 171
I believe you're correct Larry. I have at least 5 different original styles I've collected and they don't say dot.
