Speedster intake manifold
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Jul 27, 2021 10:47 am
It’s time for me to consider the intake manifold for my Akron-Hed project... I’ve considered almost every currently available manifold as a donor to be cut up and modified, and nothing seems to align with the look that I want.
I am going to run 2 of my new Winfield S-B downdrafts... and want to run a plenum style intake manifold. I really like the shape and look of the Winfield manifolds for the Model A’s... but would be a ton of work to narrow to fit the Akron-Hed, change the mounting flanges, cap the single carb flange, and add 2 B inlet flanges. So I began to design what I want. I considered machining it in pieces and welding together, but have had issues with broken welds on aluminum manifolds before. Time to consider casting. I found a relatively local foundry that will 3D print sand instead of building a pattern for a one off part.
I know there are only a few of these Akron-Hed’s out there... but if you are interested in one of these intake manifolds... now is your chance. These may fit other make overheads, but I make no claim as to fitment. Manifold will have 1.500” diameter runners, 9.438” centerline between ports, 2.750” bolt spacing on port flanges, and Winfield S-B carb flanges 5.000” apart. Minor changes to the design could also be made to accommodate other head configurations...
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Speedster intake manifold
Post by Kevin Pharis » Mon Sep 20, 2021 10:45 am
A little sand... a bit of strategically placed glue... and taaaa daaaaa! An intake manifold! Some machine work required...
Post by Scott_Conger » Mon Sep 20, 2021 10:59 am
Well, how cool is that?
NH Full Flow Float Valves
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Sep 20, 2021 11:15 am
VERY IMPRESSIVE!
I’ve done some casting where I 3d print the object in PLA and then “investment cast” using the traditional materials and then burn out and fuse the ceramic and then pour the metal and then break the ceramic. Both ways work.
All the best!
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Sep 20, 2021 11:17 am
Just thinking that we need to get the 2 up 2 down crank and cam to you!
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Mon Sep 20, 2021 11:44 am
Just what the heck can't you make, Kevin ?????
pete eastwood
First Name: Pete
Last Name: Eastwood
MTFCA Number: 52632
Post by pete eastwood » Mon Sep 20, 2021 1:23 pm
with just a quick measurement , looks like it would fit a BB Rajo .
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Sep 20, 2021 3:22 pm
The port spacing is the same as the flat head, and I hear most overheads are the same too. I will have an extra manifold laying around... that is unless I botch the machine work😉
AndyClary
First Name: Andrew
Last Name: Clary
MTFCA Number: 24057
Post by AndyClary » Mon Sep 20, 2021 8:02 pm
I know where there is a Rajo to experiment on. Can it be turned upside down?
Andy
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Sep 21, 2021 11:01 am
The manifold wouldn’t care which way it was mounted... but I’m not sure the plenum design would perform well as an updraft. The air might loose velocity and allow the fuel drop out...?
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Sep 21, 2021 4:16 pm
So lets remove the guessing:
4 valve Rajo- port centers are 9.437. Flange Bolts are 2.687 port diameter is 1.25"
B Rajo- port centers are 9.375. Flange Bolts are 2.937 (original head- not Chaffins)
AndyClary
First Name: Andrew
Last Name: Clary
MTFCA Number: 24057
Post by AndyClary » Tue Sep 21, 2021 5:15 pm
Quick measurements of a Chaffin Rajo. Intake ports 9.470 center to center. Flange bolt width 2.75 and 1.250 ports.
Those would be in inches.
Andy
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Thu Sep 23, 2021 4:32 pm
YEAH BABY!!!
Southfork Creek
Last Name: Wightman
Post by Southfork Creek » Thu Sep 23, 2021 8:01 pm
Beauty! A symphony of polished castings!!
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Thu Sep 23, 2021 10:56 pm
I don’t intend to mislead anybody... but the only castings in this pic is the iron cylinder head and the intake manifold. None of which are polished... yet!😉. All the rest is machined from solid bar. Details here for those who haven’t seen my carburetor or Akron-Hed posts;
viewtopic.php?f=2&t=14905&p=177960&hilit=Playin#p177960
viewtopic.php?f=2&t=11172&p=84063&hilit=Akron#p84063
AndyClary
First Name: Andrew
Last Name: Clary
MTFCA Number: 24057
Post by AndyClary » Thu Sep 23, 2021 11:24 pm
Isn’t the float bowl supposed to be forward, or is that just a legend and they don’t care.
Andy
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Sep 24, 2021 1:16 am
Andy
I dug into the bowl design while pondering the manifold, and found that the fuel would need to slosh at almost 45 degrees to flood out either of the spray bar circuits. That means a 1G change of direction. Arguably the greatest forces applied to a vehicle’s direction are during braking, turning being the second greatest force potential, and acceleration the least. With the bowl facing forward, the fuel would slosh into the bowl during braking, and cause the needle to seal tightly, and have virtually no chance of flooding out the motor. So yes, typically the Winfield’s are mounted with the bowls facing forward.
I figure that the carbs are resilient enough to handle a T speedster in almost any orientation... as long as the bowls are not facing the rear as this would be the most likely to flood during braking. These carbs were raced on high bank circle tracks and dirt roads for a generation, I have a feelin they’ll perform just fine turned sideways
And if they don’t... I guess I’ll have to cut up my new manifold and spread the carbs out a bit further 😬
AndyClary
First Name: Andrew
Last Name: Clary
MTFCA Number: 24057
Post by AndyClary » Fri Sep 24, 2021 9:16 pm
1938 Riley over head V-8, 4 Winfield carbs all facing the “wrong” way. This photo is from Speedy Bill’s museum, so it probably never ran this way. But Kevin’s flooding theory sounds about right.
Are the manifolds available from Non-Pharis Metals, a subsidiary of Pharis Metals?
Andy
AndyClary
First Name: Andrew
Last Name: Clary
MTFCA Number: 24057
Post by AndyClary » Fri Sep 24, 2021 9:21 pm
Forgot the picture.
Andy
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Sep 24, 2021 11:52 pm
Hmmmmm... Non Pharis Metals... 🤔 Has a ring to it, but I can barely account for myself as it is... 😉
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sun Sep 26, 2021 12:34 pm
Look y’all... no clamps!
Gonna look real nice all polished up!😁
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Oct 08, 2021 11:27 pm
Came across this backwards Winfield pic from Speedy Bills Museum today and thought bout you Andy...
Turns out the new manifold does look nice all polished up...
Dan McEachern
First Name: DAN
Post by Dan McEachern » Sat Oct 09, 2021 1:49 am
So...…. regarding float bowl orientation, I thought I would browse thru my Winfield Carburetor manual for any bowl orientation information. The manual covers installing carbs on pretty much every automobile made from 1925-1931. I found two instances where the float bowl was to be installed to the rear- 1) Model T Fords and 2) '24-'27 Oldsmobile. All others clearly stated the float bowl was to be installed to the front. So, draw your own conclusions from that.
AndyClary
First Name: Andrew
Last Name: Clary
MTFCA Number: 24057
Post by AndyClary » Sat Oct 09, 2021 1:25 pm
They probably looked at two things with the T application. One-they needed to clear the generator. Two-they probably drove a Model T and figured it wouldn’t brake hard enough to slosh any fuel.
Andy
Dan Haynes
Last Name: Haynes
Post by Dan Haynes » Sat Oct 09, 2021 3:26 pm
Truly awesome as usual. You make the best stuff.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sat Oct 09, 2021 4:07 pm
You clearly read better than I do Dan, I looked thru my catalog for some time a while back and couldn’t find anything regarding bowl orientation. One would think that if the bowl HAD to be facing front, there would be a warning on every page...?! Thanks for the info Dan, I’m dedicated now anyway... but it’s reassuring
AndyClary
First Name: Andrew
Last Name: Clary
MTFCA Number: 24057
Post by AndyClary » Sat Oct 09, 2021 8:05 pm
Manifold and carbs look great. Eastwood makes a chrome powder coating for the head.
Andy
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sat Oct 09, 2021 8:22 pm
After all the time, money, and effort... seems like money green would be the right color to paint the head😬
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sat Oct 09, 2021 8:28 pm
Just noticed that the model A water pump is installed upside down too...
Dan McEachern
First Name: DAN
Post by Dan McEachern » Sun Oct 10, 2021 3:12 am
Pretty sure you can't turn em over- must be a special pump or? The studs are closer together at the top on a stock head so...……..
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Wed Oct 13, 2021 6:47 pm
Maybe I’m just trying to convince myself that sideways carbs are goin to be OK...
And this one just posted by Hank Lee in the classifieds. Maybe he can give us some insight as to how the carbs ran on this shiny chebby. These carbs are certainly far enough apart to mount with the bowls facing forward
Dan McEachern
First Name: DAN
Post by Dan McEachern » Wed Oct 13, 2021 7:29 pm
Probably depends on how fast your engine stand will go!
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sun Dec 12, 2021 2:25 pm
Adding to my collection of “wrong” mounted Winfields...
scott hills
First Name: scott
Last Name: hills
* REQUIRED* Type and Year of Model Ts owned: 1924 Paco speedster 27 touring
Board Member Since: 2012
Post by scott hills » Sun Dec 12, 2021 7:05 pm
Kevin I have 2-3 thousand miles on this set up my only issue is that the int. jets have to run a good bit richer than normal otherwise I get a lean pop back on take off and or accelerating around a very sharp turn both left and right when it involves a heavy load ie steep pull. These are pretty small carbs though (AA). Great looking manifold by the way hope to see you on a run soon Scott Hills
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sun Dec 12, 2021 10:09 pm
Thanks for the feed back Scott! Lovin that Roof 16 Model C! My SR-C has a lean cough as well when the motors hot. I could adjust the accelerator pump, but found the pump housing barely hanging by the last screw last summer. Apparently I’m falling behind on maintenance these days...😬
It might be worth checking that your air bleeds are the correct size. Also check that the intermediate compensator is correct for the AA size (A and AA are interchangeable). There are a few variations of compensators, I would check that both intermediate compensators and air bleed sizes match (regardless of size). Float level also decides the volume in the accelerator well, might wanna check that too...
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sun Dec 26, 2021 12:01 am
With all the excitement of firing off my new carb for the first time... I completely glazed over the fact that my dad had mounted his carb “backwards” when he put the Fronty in a while ago
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Wed Apr 12, 2023 5:05 pm
It’s been a while but found another sideways Winfield installation over on the HAMB
