Ruckstell Fill Level
Posted: Wed Jul 28, 2021 10:18 am
by JBog
Is this the style of ruckstell that you fill up to the hole?
Re: Ruckstell Fill Level
Posted: Wed Jul 28, 2021 10:46 am
All Ruckstells and rear ends get fill the same amount. It is the filler hole placement on the right side housing that tells how that level is measured, Ruckstell did not make and sell the right side housing, that is Ford.
I should have used level instead of same amount. They all get filled to the same level.
Posted: Wed Jul 28, 2021 10:51 am
It's a good idea the first time you fill the rear axle with Ruckstell to Wait a while perhaps let it idle on stands for a short time, and then check the level. It takes a while for the oil to reach the internal parts. After you drive it around a while check again. After that it should stay full for a long time unless you have a leak.
Posted: Wed Jul 28, 2021 10:53 am
by JBog
Mark Gregush wrote: ↑Wed Jul 28, 2021 10:46 am
I had heard some folks say you fill up to the hole and others say that you fill to within 1 inch of the hole depending on the year of the ruckstell. I guess that must be a myth?
by JBog
Norman Kling wrote: ↑Wed Jul 28, 2021 10:51 am
Mine does leak. I need to top it off every three weeks or so.
Posted: Wed Jul 28, 2021 10:54 am
If the filler hole is toward the center of the axle tube, it should be about 1 inch below the filler. The first joint of your finger should just touch the top of the oil. If the filler hole is a little lower than the center, then fill it to the point of the bottom of the hole.
Posted: Wed Jul 28, 2021 11:19 am
by jab35
One Quart is recommended for standard differential,
http://www.modeltford.com/item/600W.aspx
I suspect the Ruckstell would require 1.5 to 2.0 qts. jb
Posted: Wed Jul 28, 2021 12:17 pm
You would think. First fill (new unit) took less than 1 quart. The rux takes a thinner oil than the standard rear end.
Rux:90 wt. Std:140 wt. (not my guess, published in rux book)
Posted: Wed Jul 28, 2021 12:47 pm
JBog wrote: ↑Wed Jul 28, 2021 10:53 am
Where is it leaking?
Posted: Wed Jul 28, 2021 1:14 pm
by JBog
Mark Gregush wrote: ↑Wed Jul 28, 2021 12:47 pm
Around the bottom of the housing where the two halves come together.
Posted: Wed Jul 28, 2021 1:42 pm
You could get lucky by cleaning the area up very well and quickly smearing on some ultra black before the oil seeps out again.
Posted: Wed Jul 28, 2021 2:03 pm
JBog wrote: ↑Wed Jul 28, 2021 1:14 pm
Some body lifted the rear end in the center. Thats a no no. Makes em a leaker.
Posted: Wed Jul 28, 2021 3:02 pm
speedytinc wrote: ↑Wed Jul 28, 2021 2:03 pm
Or it was put together without sealer or gasket.
Posted: Wed Jul 28, 2021 3:06 pm
by JBog
Norman Kling wrote: ↑Wed Jul 28, 2021 1:42 pm
Ill try this. I don't really want to take it apart this year.
Posted: Wed Jul 28, 2021 3:58 pm
As someone suggested on that other place, check your housing bolts too.
