Mag battery charger
Posted: Wed Jul 28, 2021 1:46 pm
Customer Has a 24 touring. Took the motor to a guy for rebuilding. Block was N/G. He found a fellow member with a pile of blocks. Selected a good one & had it rebuilt. When it arrives for the complete build, I notice it has no place for a generator. 1915 motor. He wants electric start.
Finished engine magneto puts out 30- 35 volts a/c. Needs a way to keep the 8V battery charged for the starter & occasional evening driving.
Since fun projects isnt available, I built one similar to the one on my 14.
Found an appropriately rated diode in the diode jar(pack rat) and a universal tail light socket. Color coded wires. (didnt have an old wire harness for cotton covered wires) All joints ere crimped & soldered.
This unit attaches to a longer upper steering column bolt.
First try used a 6V dual filament bulb. Put out 4 amps @ speed & blew.(would have worked on a 20-25V output mag)
Second try used a 12v 1157 bulb. Charges 1 amp above idle & 3 amps @ speed. Power goes thru the ammeter, so you can see it charging.
That should be enough to support the starter on day runs.
No effect on the ignition performance on mag.
