New cam bushing tool
Topic author - Posts: 596
- First Name: Brad
- Last Name: Kirtner
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
- MTFCA Number: 50618
Haven’t posted an engine build update in a while so I think I’ll start with this. I’m rebuilding the engine for my 27 closed cab TT. Doing most of the work myself I needed a tool to properly ream out the rear cam bushing in line with the front bearings. With the help of my local machine shop and a very nice guy in Washington who supplied measurements and great pictures, this tool was born. Makes reaming the rear bushing super easy and precise. Who knows how often I’ll actually need to use it but at least I have it in my arsenal now! Simple yet effective. Shaft turned down to barely slide through the bearing journals with ease. Small stub reamer held in by a set screw. The end of the shaft was machined so that it can easily be turned by hand with a wrench, length of rod stock or be chucked up in a drill. It took more time to install the bushing than to actually ream it out.
Brad
Brad
Re: New cam bushing tool
Nice job, Brad
I made one for myself and it was definitely worth the time and effort
NH Full Flow Float Valves
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Nice Work Rookie!
Hank
Hank
- Last Name: Kelly
Nice work.
- Last Name: Burgett
- MTFCA Number: 29590
I made one also. Used some aluminum round stock which made for easy machining. Not as durable as steel but fine for the purpose.
John
John
- MTFCA Number: 14972
- MTFCI Number: 15411
Copy of a K.R. Wilson reamer of mine that Brad utilized dimensions from.
- First Name: Brad
Thanks for commenting Steve. Without your help and pictures I’d be lost in the sauce! This tool really takes the build to the next level.
Brad
Brad
You are most welcome, my friend !
- Last Name: Laplander
- * REQUIRED* Type and Year of Model Ts owned: 1927 roadster
Any chance someone has one of these to sell or know where they do off hand? I won't need it until next year, but it pays to be ready and I don't have anyone who can make one.
