Here’s a wacky one ! Can you beat it?
- First Name: CHARLIE
- Last Name: BRANCA
- MTFCA Number: 28967
- Board Member Since: 2010
Re: Here’s a wacky one ! Can you beat it?
Ball type shut off valve I believe but no idea in hell what it’s for.
- MTFCA Number: 52564
It is a flip up lubricator or priming cock. Flip up to add oil or fuel, as the case may be, flip down to close. Other thing it could be, is a compression release, but with the funnel on the end more than likely not.
1920 Dodge touring
1920 Dodge touring
- Last Name: Branigan
- * REQUIRED* Type and Year of Model Ts owned: 1909 two1910, two1911, 1913 Tourings
- MTFCA Number: 52262
Thread size would help. Maybe a drain plug?
- First Name: Don
- Last Name: Demio
- * REQUIRED* Type and Year of Model Ts owned: 1919 T
- MTFCA Number: 27167
- MTFCI Number: 20405
While I have never seen anything exactly like this, it appears to be homemade rather than a production item. It looks similar to the priming cups that appear on vintage spark plugs that also have a shutoff valve/arm.
My hope is that this post will stimulate additional discussion.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Tim has it in his hands so it is "WACKY".
- Last Name: Iaccino
- * REQUIRED* Type and Year of Model Ts owned: 1911 Roadster, Open Runnabout
- MTFCA Number: 17802
Looks to me like a oil pan drain plug. Flip it down to drain without having to remove the drain plug.
Topic author - Posts: 3384
- Last Name: Morsher
Hank, I represent that remark! John wins the prize, a speed drain for Lizzie ! It’s definitely professionally made. It’s great fun for me to see these amazing gizmos that the love of Lizzie wrought. A couple of hits but so many misses.
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
Some how that seems like a bad idea. Driving in tall grass could drain your oil? It is amazing all the things made for the T. Keep em comin Tim.
Dallas, can you imagine one of those go fast boys in the 20’s installing this on his low slung Bug? That’s probably why the original T nut has such a short head on it.
Back then, I’ll bet people rarely changed their oil, but just added to it.
