Cocoran Headlight exploded diagram??
Channel1tv
First Name: Bryan
Last Name: D
* REQUIRED* Type and Year of Model Ts owned: 1921 Center Door, 1923 Depot Hack. 1915 Rajo Speedster
Board Member Since: 2008
Post by Channel1tv » Tue Aug 03, 2021 6:57 pm
Have a basket case headlight and trying to reassemble the head
Light door. Glass seems too small, have 2 wire rings. Seems there should be some gasket? A picture would be great! Diagram even better. Also all the gas lines are missing from the generator to the lamps. A diagram on how they are routed would be nice too! It is on a 1914 speedster.
If you find yourself the smartest person in your group of friends, it’s time to find some new friends!
Re: Cocoran Headlight exploded diagram??
Post by Rich Eagle » Tue Aug 03, 2021 8:07 pm
Mr. Vowell has done some brilliant work illustrating Model T assemblies. I think this one should help.
https://mtfca.com/phpBB3/app.php/gallery/image/1266
Channel1tv
First Name: Bryan
Last Name: D
Post by Channel1tv » Tue Aug 03, 2021 8:16 pm
All except the headlight door.. I have the clear glass lens. It seems too small in diameter. There is a large ring that appears to fit in the the door but, it does not hold the lens in as the lens is too small? It is great as I now have the bucket together!!!! Thanks for the Diagram!!!!!!
Channel1tv
First Name: Bryan
Last Name: D
Post by Channel1tv » Tue Aug 03, 2021 8:28 pm
Does anyone have a source for the replacement glass lens?
Post by Rich Eagle » Wed Aug 04, 2021 4:12 am
Most good glass shops can cut glass round to any diameter. If you take the door and the ring to them I'll bet they can cut one to work nicely.
Channel1tv
First Name: Bryan
Last Name: D
Post by Channel1tv » Wed Aug 04, 2021 8:41 pm
That is what I wii do, cut some new lenses. still need to know how to run the gas supply lines from the generator to the lamps. they were all missing.
Post by Rich Eagle » Thu Aug 05, 2021 11:28 am
