Cocoran Headlight exploded diagram??
Posted: Tue Aug 03, 2021 6:57 pm
by Channel1tv
Have a basket case headlight and trying to reassemble the head
Light door. Glass seems too small, have 2 wire rings. Seems there should be some gasket? A picture would be great! Diagram even better. Also all the gas lines are missing from the generator to the lamps. A diagram on how they are routed would be nice too! It is on a 1914 speedster.
Re: Cocoran Headlight exploded diagram??
Posted: Tue Aug 03, 2021 8:07 pm
by Rich Eagle
Mr. Vowell has done some brilliant work illustrating Model T assemblies. I think this one should help.
https://mtfca.com/phpBB3/app.php/gallery/image/1266
Posted: Tue Aug 03, 2021 8:16 pm
by Channel1tv
All except the headlight door.. I have the clear glass lens. It seems too small in diameter. There is a large ring that appears to fit in the the door but, it does not hold the lens in as the lens is too small? It is great as I now have the bucket together!!!! Thanks for the Diagram!!!!!!
Posted: Tue Aug 03, 2021 8:28 pm
by Channel1tv
Does anyone have a source for the replacement glass lens?
Posted: Wed Aug 04, 2021 4:12 am
by Rich Eagle
Most good glass shops can cut glass round to any diameter. If you take the door and the ring to them I'll bet they can cut one to work nicely.
Posted: Wed Aug 04, 2021 8:41 pm
by Channel1tv
That is what I wii do, cut some new lenses. still need to know how to run the gas supply lines from the generator to the lamps. they were all missing.
Posted: Thu Aug 05, 2021 11:28 am
by Rich Eagle
