Engine missing issues
Posted: Tue Aug 17, 2021 3:58 pm
by Truck 20
I have a 26 T engine that has been fully rebuilt a couple of years ago. It is missing on #1 cylinder because when I short out the plug it slows the engine down very little. Compression is 52 lbs across the cylinders(dry) I didn't do it wet. Has new plugs, wires, Anderson Timer and I have changed the coils out and still have the same issue. I have had the engine running in the dark to make sure I don't have any shorts from the coil box and I found none. When I took the plugs out of #1 and #2 plug they were blackened like they were running rich and the other two were white. It has a alum. high compression head, could this be the problem in some way??? Happy to hear about any other ideas to look at....
Larry Holderman
Warsaw, Indiana
Re: Engine missing issues
Posted: Tue Aug 17, 2021 4:06 pm
Test for intake manifold leak on rear port. Spray some ether around it whall running.(starting fluid)
Classic intake manifold leak symptom.
Two clean and two sooted plugs is not a problem, it is a symptom.
Easy and cheap fix
Posted: Wed Aug 18, 2021 7:26 am
by Truck 20
Thanks for the replies, when I get a chance I will give that a try
