Safety Hub O ring
Posted: Wed Aug 18, 2021 11:08 am
by Will
Pulled out my hubs today as there was some oil on the axle nut and found the safety hub O ring was broke. Would someone know what size it is? I tried one I have and it was to thick. Thank you.
Re: Safety Hub O ring
Posted: Wed Aug 18, 2021 11:45 am
by Dropacent
Lots of versions of these out there Will, so probably easiest to take the hub to a good auto store or hydraulic rebuild shop, they can fix you up. Lube them up good when carefully installing and get a couple spares while you are there, just in case you tear it on install. They are cheap. Good luck!
Posted: Wed Aug 18, 2021 11:51 am
Measure the ID of the groove and its width, then go here: https://www.parker.com/Literature/O-Rin ... 205700.pdf
O-ring measurement information and size listing starts on page 89. The other stuff is design information which you may skip.
The o-ring you want will begin with "2-" and the following 3 numbers will refer to the specific o-ring in the "2" range.
Posted: Wed Aug 18, 2021 12:37 pm
by Dan McEachern
Try a 225 O-ring.
Posted: Wed Aug 18, 2021 7:01 pm
Or simply install it in a dry housing using a liberal coat of black RTV sealant. The bore of some axle housings is not kind to O rings.
Posted: Wed Aug 18, 2021 7:31 pm
Re; "The bore of some axle housings is not kind to O rings" That, is for sure! I run a hone through it a few times just to clean it up some, not to resize. Ford was not real careful when it came to the machining on some, if not most.
Posted: Thu Aug 19, 2021 8:59 am
by Will
Thanks guys, I ended up measuring the old ring and and ordering the 225 as Dan mentioned. I'm going to run a hone as Mark mentioned just to clean it up. I think maybe some of the problem could had been was maybe I might of had just a little bit to much oil in the gear case.
Posted: Thu Aug 19, 2021 2:53 pm
by Will
Steve( RajoRacer ) I got your e mail but for some unknown reason I could not reply. I hope you find this, I got the rings from McMaster -Carr. The part number was 226 BUNA 70. I had to buy 100 of them so send me your mailing address and I will send you out a few. Will C
