1921 Center Door Gas Tank Mounting Question
Posted: Thu Aug 19, 2021 8:43 pm
by AZVT
I need some help figuring out how to mount the gas tank located under the driver's seat on my '21 Center Door. Does it sit on top of the floorboards and be held in place by the driver's seat and if so how is it bonded to the car's frame? I can't find any photos online or an explanation on how it is attached? If you can post some pictures that would be a great help! Thanks...
Re: 1921 Center Door Gas Tank Mounting Question
Posted: Thu Aug 19, 2021 8:57 pm
by FordFool
In my 20 it’s held in place by the seat. Pretty tight fit no room for hold down brackets.
Posted: Fri Aug 20, 2021 5:32 am
by mtntee20
+1 Held in place by the seat frame. When I removed the driver's seat in ours, it all came out as one piece. Haven't taken it apart yet to see how it's secured in the seat frame.
Posted: Fri Aug 20, 2021 8:06 am
by AZVT
How (or is it) bonded metallically to the frame or is it isolated? Seems like a risk of static discharge without an electrical/mechanical bond to the car's frame.
Posted: Fri Aug 20, 2021 11:42 am
by George House
Jamie, it’s not attached to the frame at all. As previously mentioned, it’s captured inside the drivers seat.
Posted: Fri Aug 20, 2021 11:44 am
by TXGOAT2
Pssst! DON'T TELL RALPH!
Posted: Fri Aug 20, 2021 1:15 pm
by Mark Gregush
AZVT wrote: ↑Fri Aug 20, 2021 8:06 am
It would be grounded through the supply pipe that feeds the carb. If worried about grounding and using rubber connections, you could mount a ground between the seat frame and floor mounting screws, then running it to the frame somewhere.
You are not just sitting on the gas tank directly, there is a carpeted surround that mounts to the floor that the gas tank sits in. Do a search of "mtfca.com; center door gas tank".
