Paint remover
Posted: Wed Sep 01, 2021 5:20 pm
by John Illinois
Is there a good paint stripper that the EPA has not banned ? Aircraft remover used to be good. I am stripping a radiator shell.
John
Re: Paint remover
Posted: Wed Sep 01, 2021 5:52 pm
by TeveS-Nor Cal
Easy-Off oven cleaner
Re: Paint remover
Posted: Wed Sep 01, 2021 7:12 pm
by CudaMan
3M used to (and may still) sell a product called "Safest Stripper". I have used it in the past with good results and can confirm it is not nearly as caustic as classic stripper. :)
Re: Paint remover
Posted: Wed Sep 01, 2021 7:30 pm
John
All depends on the kind of paint. Aircraft Remover is about the only thing for Powder Coat. Lacquer thinner works on some. Most of the new stuff is citrus based and works well. Start with what yo u have and if that doesn't work - follow recomendations
Re: Paint remover
by ivaldes1
Citri-strip and a wire wheel on a drill or grinder works well. It usually takes 2 or 3 treatments though to get all the last little bits off.
Re: Paint remover
Posted: Thu Sep 02, 2021 8:39 am
by John Illinois
Thanks for the suggestions. I will see what is available.
John
Re: Paint remover
Posted: Thu Sep 02, 2021 9:43 am
by GridLeak
water lye corn starch .I am not pc
