Tool found in Model T parts
Posted: Sat Sep 11, 2021 6:26 pm
by Unprr
I found this tool, with Model T parts, I purchased last week.
The name on the side is very faint but it appears to be ( New Britain VL-200 ).
Any clue, what it is?
George Schmidt
Elkhorn, Nebraska
Re: Tool found in Model T parts
Posted: Sat Sep 11, 2021 6:28 pm
That's a valve spring compressor. It may be designed for a Ford flathead V8. It could probably be used for others.
Posted: Sat Sep 11, 2021 6:55 pm
by Wayne Sheldon
Not intended for a T, nor needed for one. However, will work very well with a T (I would imagine?). I have one very similar to that, used it once on a modern V8 (can't now remember why I needed to compress an overhead valve on an assemble engine?). Used upside down and/or backwards it was tricky, but got the job done?
I have others I use on the Ts and they seem to be easy enough. My one like that just hangs on a wall in case somebody (me or anyone I know) needs it.
Mine is one of the many tools my dad had, and he wasn't sure what it was for.
Posted: Sat Sep 11, 2021 8:00 pm
by Don D
Stanley Tool was based out of New Britian, CT. I'm not sure if this helps but my 2 cents!!!
Posted: Sat Sep 11, 2021 8:53 pm
by Unprr
Thanks to all who replied. It will make a nice wall art. LOL.
George
Posted: Sat Sep 11, 2021 9:44 pm
by MichaelPawelek
Though slow that would make one hell of a cherry pitting device…😊
PS-Have a similar one on my wall.
Posted: Sun Sep 12, 2021 8:51 am
by tmodeldriver
That's a valve spring compressor for over-head valve engines.
Posted: Sun Sep 12, 2021 9:22 am
The spring fork shown is made for small diameter springs typically found on older flathead engines. OHV engines require larger (overall) springs to control their larger valve train mass. The tool may have come with several sets of spring forks to accomodate Fords, Chevrolets, and Buicks. It will work with many OHV heads, and it remains a useful tool.
Posted: Sun Sep 12, 2021 11:39 am
by Craig Leach
Yep thats a valve sring compesser. They make them in all sizes from Briggs & Straton to big truck. I prefer them to most made for model T's they give you more room to install the pin in the valve stem. You can add washers to the yoke if its to small for what you are working on (up to a point)
It's allways great to get bonus tools.
Craig.
