Tank wood mount blocks fitting...
Posted: Wed Sep 15, 2021 2:35 am
It is really coming together enough to start putting the tank on. Unfortunately the pre-cut Lang's block do not fit my tank. The tank is very oval at a steeper angle. So my choices are cut my own or somehow pack the wood block angle with some material. The wood mounts I have also won't mount to the floorboard without blocks under it. I think I need to make some mounts that will bolt to the side wall of the wood body and suspend it off the floor board so I can get to my battery anyway. That means I will need straps too. Any suggestions on making tank straps? I don't know if Lang's tank straps will work or not.
