Length of rear axle shaft
Post by Norman Kling » Wed Sep 15, 2021 9:21 am
What is the length of the standard rear axle shaft. This would be the one with the tapered end with a key for the hub. VS the length of a "Wide Track" shaft? This would be the length from the differential to the end of the shaft for one side of the axle.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Re: Length of rear axle shaft
Post by CudaMan » Wed Sep 15, 2021 10:18 am
Post by Norman Kling » Wed Sep 15, 2021 10:57 am
Thank you Mark, however, I don't find the answer to my question. I need the length from the tip of the threaded end to the inner end where it fits to the washer between the two axles.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Wed Sep 15, 2021 11:15 am
Doing the math from the diagram that Mark linked, I ended up with an overall length of 30 & 7/8". I can measure an axle out in the shop later.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Wed Sep 15, 2021 11:15 am
Adding up the partial lengths shown on the drawing, I get an overall length of 30.875 inches. However,....
I just measured two new axles I have in my basement and got an overall length measurement of 31 1/8 inch for each. These axles were from Chaffin's and were advertised as being 1/16 inch longer than stock, so that would put a stock axle length at 31 1/16 inch, or 31.0625 inches.
I can't explain why my measurements don't match up with the sum of the dimensions on the drawing. :(
You could try calling Snyders for the length, their website says they offer stock length axles made per the Ford drawing except in more modern steel.
https://www.snydersantiqueauto.com/Prod ... /axle/rear
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Wed Sep 15, 2021 12:05 pm
Beware of the reproduction axle shafts made for cars with non authentic so called Rocky Mountain Brakes, which are 1/16 longer.
Post by Norman Kling » Wed Sep 15, 2021 4:10 pm
Thank you. I don't need new shafts, but I was wondering whether he might have a "Wide Track" car. The front axle seems to be long. The front wheels come right to the edge of the fenders. The rear axle might be standard and front a wide one?
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Wed Sep 15, 2021 5:06 pm
Front axle description sounds like wide track. Right out the fender edge with wide track fenders. Wide track fenders??
Tires would stick out past fender edge with standard fenders & wide front axle.
My fuzzy head says rear axles are each 2" longer. Fenders are only 1" wider each. On 14 & later, fender edges are further out than running board edge. Non wide, fender & R/B edges are in line.
Kerry
Last Name: van Ekeren
Post by Kerry » Wed Sep 15, 2021 5:51 pm
Period Parts books, rear axle 31-1/16". A wide track front axle would put the front wheel about 1/2 it's tyre width out side a standard fender.
