Top of top ring to engine deck recommended distance?
henryford2
First Name: Joseph
Last Name: Andulics
MTFCA Number: 9766
Post by henryford2 » Thu Sep 23, 2021 10:42 am
Working on a custom piston and was looking for suggestion on what is a recommended distance from the top of the top ring to the deck? Thanks
MTFCA Number: 51486
Re: Top of top ring to engine deck recommended distance?
Post by TXGOAT2 » Thu Sep 23, 2021 10:51 am
All modern automotive type pistons I've ever seen have around 3/8" above the top ring, probably to give some protection from heat and facilitate keeping some lube available to the ring. Reducing the dimension could improve efficiency, but would most likely place the top ring in a more stressful environment.
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Thu Sep 23, 2021 11:09 am
I have seen rings go just below the top edge of the deck. I believe my 292 pistons over an A crank rajo head are this way. Not had an issue & the motor has been in operation since the late 60's. Extra heat could be something to consider, but in such a motor, they tend to run rich. I might consider 1 ring width from the top as extra safe.
MTFCA Number: 51486
Post by TXGOAT2 » Thu Sep 23, 2021 11:13 am
Antique wide rings can go to the top. I'd be cautious about pushing a modern, narrow ring too near the top.
MTFCA Number: 24868
Post by Jerry VanOoteghem » Thu Sep 23, 2021 12:47 pm
The block in my Touring had the top deck milled .060" The top ring comes just about even with the deck. Been running that way for 45 years now.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Thu Sep 23, 2021 10:44 pm
If you are ordering pistons from Ross... I would trust their guidance. They have basic designs on file for both Model T and A pistons, and they are experts in this field.
I ordered pistons from Ross years ago before they had a T piston on file... simply told them to build an A piston with specific bore dimension, pin to deck height, and dome dimensions. They decided the skirt type and ring pack details. Still running strong 10+ years later
Kerry
Last Name: van Ekeren
Post by Kerry » Thu Sep 23, 2021 11:15 pm
Can also depend on who did the machining of the rod bearings, not all have the center to center spot on.
henryford2
First Name: Joseph
Last Name: Andulics
MTFCA Number: 9766
Post by henryford2 » Fri Sep 24, 2021 7:17 am
Thanks everyone for the help. The issue I'm facing is that the crank (Model B) has been stroked giving the engine a 4 5/8" stroke, so the new aluminum version of the model T piston will have the top ring pop out above the deck.
MTFCA Number: 51486
Post by TXGOAT2 » Fri Sep 24, 2021 10:40 am
Maybe you need short rods and slipper skirts.
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Fri Sep 24, 2021 11:46 am
In the day, there were other make pistons used. Olds possibly. 292 ford. My rajo T has 292's. A crank & rods. With the stroke you may be forced to custom made. Does Scat have any input. He is a real friendly resource.
henryford2
First Name: Joseph
Last Name: Andulics
MTFCA Number: 9766
Post by henryford2 » Fri Sep 24, 2021 2:35 pm
The rod I'm using is 7" the same as the Model T
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Fri Sep 24, 2021 2:48 pm
Look into the 292. the top is square but can come up from the bore to the top ring. That's how mine fits.
I dont know the exact dimension differences you are working with.
