Blockley Tyre Update
Posted: Thu Sep 23, 2021 1:57 pm
by SMHnat
I received and email from Blockley Tyre in England and they are going to put some pallets together of 30x3, 30x3.5, and the 21s, as well as metal stemmed tubes. He is going to see again how many he can get on a pallet. Shipping is still a pain, but he is wanting to move forward and so do I. I let you know when they send the pallets over to me and the tyres are availible for purchase here in the US. Shipping to Canada will be available too.
Re: Blockley Tyre Update
Posted: Thu Sep 23, 2021 2:56 pm
by Retro54
Congrats Seamus! Couldn't be a better person to be the spearhead on this. I imagine now you'll become even more famous.... or infamous... ha.
Posted: Fri Sep 24, 2021 8:18 pm
Seamus, you might suggest that they use the plastic bins in metal frames, [don't know what you guys call them] With the top cut off they can stack them up to the top, fit more standing up on the sides, and have no worries with a stack of rubber tyres getting loose in transit, or perhaps some going missing. These bins are a standard volume and make for easy shipping calculations. They are pallet sized, but much more convenient to use.
Hope this helps.
Posted: Fri Sep 24, 2021 9:20 pm
What's the deal with Blockley tires? Never heard of them.
Posted: Fri Sep 24, 2021 10:44 pm
They claim much higher quality (longer lasting) than other Model T tires.
https://www.blockleytyre.com/product/30x3-5
Posted: Sat Sep 25, 2021 3:58 am
Their addition of beaded edge tryes to the quality range of vintage high performance tyres offered by Blockley is a direct consequence of the rubbish tyres foisted on T owners by the present cartel . At last we can buy a BE tyre that is fit for purpose.
Posted: Sat Sep 25, 2021 4:47 am
by dykker5502
.. and apart from Seamus himself, we are some that are testing that claim.
On top of that, the lettering and the thread looks very true to the tires you had back then, particular pre-1920.
Posted: Sat Sep 25, 2021 5:21 am
by Wayne Sheldon
I am hoping I will need a bunch of inner tubes soon (30X3 and 30X3.5). Current price or availability?
Posted: Sat Sep 25, 2021 10:07 am
Wayne, I think it depends on what you want. I would check the tire websites and phone or email the inquiry.
Posted: Sat Sep 25, 2021 10:34 am
They do look good mounted. [ His occupation: If we told you, we'd have to kill you. His automobile: Bugatti, of course. His cigarette: Players. His drink: Cutty Sark, over polar sea ice. His tyre: Blockley, naturally. ]
Posted: Sat Sep 25, 2021 11:30 am
I would like to see them offer tubes with just the hole in them for the valve stem. Why? The current valve stems I've seen are not the same as originals.
It's a lot of work to remove the rubber stems to accept the PROPER valve stems. Is that asking too much?
Posted: Sat Sep 25, 2021 8:42 pm
by Rich Bingham
Are the Blockley 30x3-1/2" tyres "oversize" ??
I'm saving me pennies and awaiting a stateside connection with baited breath (just ate a sardine ;) )
by Rich Bingham
Double post. Sorry. :oops:
Posted: Sat Sep 25, 2021 8:51 pm
by Kevin Pharis
Nope! Just mounted my new set this afternoon😁
Posted: Sat Sep 25, 2021 9:01 pm
by ewdysar
The only 30x3 1/2 tires available today that measure just 30” in diameter are the Firestone smooth tread ones, the Universal clincher ribbed tires are just a smidge bigger . The Wards Riverside, Universal T-drive, and Firestone blackwall tires are all about 31.3” to 32”. The Blockley 30x3.5 tires are listed as 795mm diameter, which converts to 31.3”.
So, yes, I would consider them to be “oversize” like the other O/S styles available in the US.
Eric
Posted: Sat Sep 25, 2021 9:16 pm
by TRZim
Where did you find tubes with metal stems for wire wheels?
Posted: Sat Sep 25, 2021 9:24 pm
by Kevin Pharis
Here is a Blockley...
Here is a Universal grey ribbed...
Both tires are brand new, aired up to 50 psi, and on a car. I’m on board that they are not a true “on size tire”, but are certainly closer than most
Posted: Sat Sep 25, 2021 9:28 pm
by Kevin Pharis
This is the first time I have ever splurged for metal stem tubes. They are Blockley tubes and are twice the thickness of the Hartford tubes (I measured). Also trying the “no flaps” approach for the first time as this is what Blockley recommended. I have not tried to figure out what hardware and caps would be needed to finish it all off yet...
Posted: Sat Sep 25, 2021 9:40 pm
I haven't seen the Blockley tubes, but I gather they have the same width metal stems as all the others currently available. While they are "incorrect" in Model T terms, all the reproduction hardware and dust caps are also oversize and will fit them. Original hardware and covers in the wide size are also pretty easy to find.
Posted: Sat Sep 25, 2021 10:15 pm
by ewdysar
Thanks for the first hand observation, Kevin. It shows that most specs should be good enough for comparison shopping, but direct observation delivers more accurate info.
Eric
Posted: Sun Sep 26, 2021 11:05 am
by Rich Bingham
Yes, thanks Kevin ! I've yet to dismount a rear tire on my '13, the T-driver
30x3-1/2" tires are so generously oversized I'm dreading it. Practically no clearance at the fender lip. Looks like Blockleys will be a much better fit.
Posted: Sun Sep 26, 2021 11:43 am
by Oldav8tor
If the quality of the Blockley Tires is as good as the Blockley Tubes they should be great! I currently have five Universal T drivers with 5000 miles on the four drivers. My question would be whether the Blockleys are significantly smaller than the T Drivers which would necessitate buying five instead of four (so the spare matches).
I'd also like to extend my best wishes to Seamus... I hope he can make a go of it without it becoming all consuming of his time.
Posted: Fri Oct 08, 2021 10:25 am
by Rich Bingham
Nagging you, Seamus, thanks for your patience. I just reckon it's time for a monthly update, even if the news is "nuthin yet". :lol:
Posted: Sun Oct 10, 2021 10:00 am
by Rich Bingham
Hmmm. No further interest ? :shock:
Posted: Sun Oct 10, 2021 10:53 am
I need to know more about the tubes. I understand the Hartford brand is the best available now. I need to know more about Blockley. If their tubes come with incorrect metal stems, it seems a shame for me to have to cut them off to put the real thing on. I think someone needs to talk Schrader into making the correct valve stems again, so they can be installed at the factory like original.
Posted: Sun Oct 10, 2021 11:19 am
by Rich Bingham
I need to know more about the tubes . . .
Hear !! Hear !!
Posted: Sun Oct 10, 2021 1:05 pm
by Kevin Pharis
While I doubt Schrader would see the lucrative financial opportunity to produce these valve stems in relatively minuscule quantities... this is your chance to start a new business venture...
Posted: Sun Oct 10, 2021 1:10 pm
by Kevin Pharis
Hear !! Hear !!
I didn’t snap pics of the Blockley tubes... but did measure the thickness of the material. The Blockley tubes are 2x the thickness at the couple Hartford tubes I have laying around. The metal stems are vulcanized into the tubes. FWIW, the mold finish and attention to detail of the Blockley products is very impressive
Posted: Sun Oct 10, 2021 1:19 pm
by Rich Bingham
Great testimonial Kevin, and I thank you. Your input helped me make up my mind to get a set. My problem now is HOW ?!?
How did you go about buying yours ? For me, time in delivery is no object, but I do want to buy a set.
Posted: Sun Oct 10, 2021 1:47 pm
by DHort
Just go to blockleytyre.com and order away. Or you can contact them by phone. Long distance charges apply.
Posted: Sun Oct 10, 2021 3:31 pm
by Kevin Pharis
Ordering via the web was smooth... PayPal was required for export orders, and they have their own idea of what the currency exchange rate is...🙄
Posted: Sun Oct 10, 2021 4:38 pm
by Dan Haynes
Rich B. -
I'm pretty sure Seamus has spent the past week wandering the aisles at Hershey and hasn't been keeping up on the forum. I week or two ago he was excited about coming events with Blockley progress.
Posted: Sun Oct 10, 2021 7:12 pm
by Rich Bingham
Dan, thanks for that reminder ! Out here in the wild west, 2200 miles away, it's easy to forget about the Hershey Holy Days of Obligation. As I said, I'm in no hurry, and I hope Seamus has a great time there ! Thanks to all who posted to the update !!
Posted: Sun Oct 10, 2021 7:38 pm
by Retro54
Rich B. -
Seamus brought a tube to Hershey. The thickness and apparent quality upon inspection is awesome! Having just put Hartford tubes on it was easy to FEEL the difference! I'm sure once Seamus is home he will respond. I think he left Hershey this (Sunday) morning.
Posted: Sun Oct 10, 2021 8:29 pm
by Wayne Sheldon
I need 6 to 8 inner tubes! As much as I do not want to have to 'pay the price'? I am so disgusted with all the tubes I have seen in the past fifteen years that I want to one way or another get the best tubes I can!
I also have not used PayPal for several years, and thanks to my 'bank' breaking its promises to me (and thousands of other customers I might add!), the account that was connected to Pay Pal no longer exists. So other means of payment would be preferred over opening a new PayPal account.
So I patiently await word that tubes become available soon through a local distributor (YAY Seamus!)
Posted: Mon Oct 11, 2021 4:19 am
by Alan Long
Gents,
I agree with others and wouldn’t ruin a brand new tube and be loathed to cut out its Metal stem to fit an original one!
They are the same size as the originals with a quality vulcanising job.
Tubes are twice the weight of others and 100% Butyl, NOT a mixture of Viton, Nitrile and other who knows what rubber compounds melted down.
100% Butyl is what was used in the olden days and prevents air passing through it creating a pressure loss.
Hartford would be my second choice as some have had good experiences with them.
When it comes to a critical safety item that Tyres and Tubes are, I go for the very best that is currently available.
$2000 or just over is a great investment in safety and long life on a set of Tyres and Tubes in my opinion.
Alan in Western Australia
Posted: Mon Oct 11, 2021 10:19 am
Are the Blockley tubes only going to have the incorrect metal stems? Are any of them going to have rubber stems that should be easier to cut off.
What I hate about most reproductions, they are never done correctly.
Posted: Mon Oct 11, 2021 9:50 pm
Cars other than Model T's use 30 x 3.5" tubes. Are they wrong for all cars???
Posted: Tue Oct 12, 2021 4:20 am
Well, Original, looks like you are stuck with other brand rubber stemmed tubes. Myself, I'd much rather tubes which hold air. I can live with the larger stems used on most other cars.
Posted: Tue Oct 12, 2021 4:34 am
by Wayne Sheldon
I would much prefer stems of the correct size myself. However, I am fairly sure I can live with the larger stems IF the tubes are good, reliable, and hopefully patchable if needed. Most synthetic tubes in recent years won't hold a patch at the pressures required for clincher tires! If I have to, I can drill my rims/wheels to allow the larger stems. I know I know, some wooden felley wheels have thin steel sleeves to pass through the wood. But I suspect the small increase in size (with the steel sleeves removed) won't seriously harm the wheel.
Posted: Tue Oct 12, 2021 7:39 am
by SMHnat
I emailed Blockey on Saturday and said their is great demand here for their tubes and tyres! I asked what's the hold up, besides covid, and what's taking so long to get this rolling?! I'm making it easy for them, I think. I very well may just take the charge and give them a call!!! Its tuesday, havent heard from them again.... sometime Julian responds in a couple day, but sometime a couple weeks.
Posted: Tue Oct 12, 2021 11:39 am
Most likely not necessary. I use the larger "wrong" size in my wood felloe wheels. No alterations needed.
Posted: Tue Oct 12, 2021 1:34 pm
by dykker5502
I second Steves statement above. I just mounted my Blockley tires with Blockley tubes on my 30" x 3½" rearwheels on my 1914. No modifications needed, but yes, it was hard to get the stems aligned and put through the hole.
Posted: Tue Oct 12, 2021 6:50 pm
by Wayne Sheldon
Almost twenty years ago, I did get a couple oversize stem model T tubes (they are some of what will not hold a patch over 40 psi!).
What I discovered then, was that some of my model T wheels would accept the oversize stem with no problems. However, a few of my model T (wood felley) wheels would not let the oversize stem pass through. My simple solution then was to use the couple oversize stem tubes in the wheels I had that would take them, and use a couple proper size stem tubes I had in the wheels that would not allow the oversize stems. I really did not like that. Because it meant that in the future, it would be possible to require a tire repair and hit that obstacle in a less convenient time and place. However also, I really did not want to unnecessarily alter my original wheels.
At this point in time, I am ready to surrender to the realities at hand (the ability to adapt to situations is one of the most important of all survival attributes!). I have wheels restored and waiting for tires which are waiting for tubes. I haven't checked to see if/how many will need modification to accept the available stems (because I kept hoping for better options?). And I really don't wish to fool around with cutting out the oversize stems in order to install original stems (which I do have a few of) because of the size difference and my more recent experiences with modern tubes not holding patches at higher pressures
Been a long time since I tried to vulcanize tire patches. However, the Chem-bond type patches in recent decades do not hold if the tire pressure exceeds about 40 psi. Numerous and very careful attempts to patch seam leaks (poor quality manufacturing!!) and even a couple self inflicted tire tool pinches resulted in tires that would hold 35 psi for several months! However, once I upped the pressure to 45 psi, the patch would peal off on one side and the tire would be completely flat in hours.
Whether the change has been in the tubes themselves, or the patches and glue, or both? I don't have the answer. I have been patching tubes with Chem-bond type patches since I was eight! I would like to think I know what I am doing. But nothing I have patched in the past 15 years has worked at any more than about 35 to 40 psi (I actually upped the pressure on one very gradually, at 38 psi, it failed!). Doesn't work very well for tires that require 55 to 65 psi to remain tightly on the rim.
Posted: Wed Oct 13, 2021 4:25 am
Michael, did you put the tube inside the tyre first? Then inflate it just a bit? Then fit BOTH beads with the valve stem down the hole? Once that is done, a clamp can be applied while you lever the tyre, both beads at a time, over the rim.
Fitting one bead, then trying to wrestle the valve stem down a wooden felloe valve stem hole is fraught with difficulty.
