inline water filter on radiator hose
Posted: Sat Sep 25, 2021 10:09 pm
by brisketbill
does anyone use inline water filters on the radiator hose
Re: inline water filter on radiator hose
Posted: Sat Sep 25, 2021 10:17 pm
by Alan Long
I do run one on the 66 Mustang only because it was there when I bought the car. It does catch a fair amount of junk.
Others may have experience using them on T’s and whether they have a negative effect on the Thermo Syphon System.
Alan in Western Australia
Posted: Sat Sep 25, 2021 10:54 pm
by Scott_Conger
What exactly are you protecting with one?
Posted: Sun Sep 26, 2021 12:16 am
by Steve Jelf
What?
What?
What?
Posted: Sun Sep 26, 2021 6:26 am
by Allan
Why? WHY? What the heck for? A model T cooling system needs no impediments.
Posted: Sun Sep 26, 2021 7:47 am
by MichaelPawelek
I would display it on the shelf with my water pump collection….
Posted: Sun Sep 26, 2021 10:29 am
by TXGOAT2
If the system has loose debris in it, flush it. Unless the filter is enormous, it will plug quickly if there is anything loose in the system.
Posted: Sun Sep 26, 2021 12:12 pm
by TRDxB2
Adding a water pump is usually an attempt to solve a over heating problem. Adding a water filter may be an attempt to solve or prevent a similar issue. Like most questions: Why did you ask - curiosity or results of a flush?
Posted: Sun Sep 26, 2021 12:32 pm
by speedytinc
If you are already running a water pump, maybe it will catch crap until it plugs up. If your system is still thermosyphon, NO. Any impedance will mess with your cooling. This is as good an idea as putting on inline fuel filter. "Why doesnt my T run up hill?"
Posted: Sun Sep 26, 2021 9:02 pm
by Jerry VanOoteghem
Let's go easy on the OP, he's a first time forum user.
As you can see, a filter is not really a good idea for a T cooling system. :)
Posted: Sun Sep 26, 2021 9:55 pm
by speedytinc
I do hope the OP understands no malice or taunting is intended. We are trying to help educate the gentleman.
Posted: Mon Sep 27, 2021 8:33 am
by Alan Long
Gee Wizz, that’s a very fine filter and nothing like the Cone shaped, Plastic one in my Mustang Top Radiator Hose which would
only catch real big stuff, so basically useless. No way would I fit any filter in any of my Model T’s
