Backfiring going down hill
Posted: Mon Sep 27, 2021 8:19 pm
by Dennis K Anderson
What makes a model t engine backfire going down hill. The throttle is all the way up. Is it carburetor or timing?
Dennis K Anderson
Maryville Tn
Re: Backfiring going down hill
Posted: Mon Sep 27, 2021 9:07 pm
by Scott_Conger
Running very lean under those conditions. My Austin Healey would do that too, when downshifting. Never done that in the T.
Posted: Mon Sep 27, 2021 9:20 pm
by Don D
Dennis,
I am not a mechanic just a parts changer. :-) If you are referring to that beautiful Postal Truck you built I think the issue may be a loose nut behind the wheel buddy. Seroiusly, call me, I have a spare rebuilt carb you can borrow to see if yours needs to be rebuilt.
May best to Ms. Connie,
Dom
Posted: Mon Sep 27, 2021 9:21 pm
by Norman Kling
If the spark is retarded going downhill, the spark will come late, causing some of the fuel to ignite in the manifold or muffler.
Posted: Mon Sep 27, 2021 9:24 pm
by Bill Robinson
Dennis- I'll bet that you are not running a standard Model T muffler. I'm running a muffler for an 8N tractor on most of my T's and they all backfire going downhill, but only if the timing is retarded. They are tough mufflers- much tougher than the Ford take-apart mufflers that are destroyed by a backfire.
When my granddaughter was young we'd be on a tour and I'd make the car backfire and she be in the back seat yelling "do it again, Poppy!" :D
Cows on the roadside hate it. :lol:
Posted: Mon Sep 27, 2021 11:17 pm
by Jerry VanOoteghem
Describe what you mean by "backfire". Do you mean explosions in the muffler, or "popping back" out of the carburetor? Each has a different cause.
Posted: Tue Sep 28, 2021 5:22 am
The backfiring is in the muffler. I am running one of those stainless steel mufflers. I don't think it will burst apart, but popping like that can't be too safe. Your commits are helpful and I will continue to chase this problem. Dom, I have been looking for that loose nut behind the wheel for a long time. Can't seem to find it. Thanks.
Dennis K Anderson
Maryville Tn
Posted: Tue Sep 28, 2021 6:50 am
by Charlie B in N.J.
What Mr. Kling said.
