Is this Threshold Correct?
Posted: Sat Mar 23, 2019 8:28 am
by SurveyKing
Can someone post a photo of a correct threshold for a 23-25 Rear Touring Door? This photo is of my right rear threshold for my 1924, should the metal pieces be joined here or is this correct?
Looking down on the right rear threshold
Re: Is this Threshold Correct?
Posted: Sat Mar 23, 2019 8:40 am
Correct, except typical production the wood filler pieces above the sill are tapered up and a bit more flush with the edges of the metal threshold at each upper corner. The exposed wood painted with body pieces installed.
Posted: Sat Mar 23, 2019 9:02 am
View at rear seat heel panel
View at front seat backrest toe panel
IMG_3123 (600x450).jpg (92.62 KiB) Viewed 4706 times
Another view rear seat toe panel
Posted: Sat Mar 23, 2019 10:14 am
by SurveyKing
Thanks Dan for posting those pics, a big help. Would you know what kind of wood those filler pieces are?
Posted: Sat Mar 23, 2019 11:07 am
by HornsRus
buy 23 wood was hard to get so most was pine. or any scrape on the floor.ha,ha. that's why they went to steel bodies. charley
Posted: Sat Mar 23, 2019 1:10 pm
by SurveyKing
Hi Charley, did you get my list of bolts, nuts that I need? Daniel Snell
Posted: Sat Mar 23, 2019 10:35 pm
by SurveyKing
Dan Trace, On this photo I have circled a lip that is on the narrow threshold below the door. Is this lip supposed to go into a slot on the wood rail below? Mine is just resting on the wood rail and there is a space below it.
Lip on Threshold
Lip on Threshold
Posted: Sun Mar 24, 2019 5:02 am
Daniel. Isn’t a slot in the wood sill, that stamped metal threshold piece just folds over. Variations in assembly of parts will occur with our Model T’s!
Posted: Sun Mar 24, 2019 9:52 am
by HornsRus
yes i have your list! i will be working on it. charley
