Correction Collapsed carburetor float
Posted: Fri Oct 01, 2021 4:24 pm
by LesAlderson
Anyone seen a collapsed carburetor float and if so what the cause might be.
This is a Holly G on a 1925 TT.
- IMG_2655.jpg (20.42 KiB) Viewed 1567 times
Re: Melted carburetor float
Posted: Fri Oct 01, 2021 4:38 pm
by Rich Bingham
Can you identify the float material ? If it's some kind of synthetic (plastic) it would be a latter-day replacement that has succumbed either to an unusual amount of heat or perhaps elements in the ever-changing brew that gasoline has become in recent years. The original floats were either cork or brass.
FWIW, the Holley G, introduced in 1914, was phased out by 1921 I believe. (careful archivists will inform us correctly). The Holley G is a fine carb that will work well on most any year T or TT, and replacement floats are readily available from T parts suppliers.
Posted: Fri Oct 01, 2021 5:04 pm
by LesAlderson
Upon further examination, it is a plastic, hollow float that has collapsed.
It does not appear to have gas inside the float.
Posted: Fri Oct 01, 2021 5:31 pm
by MichaelPawelek
3D printers aren’t practical for everything….,
