Question About Steel Rim Tires
Posted: Mon Oct 04, 2021 9:54 pm
by BLB27
Are the 11/2" rim liners ok for my 1927 wheels or do I need the 5" wide rim flaps?
Re: Question About Steel Rim Tires
Posted: Tue Oct 05, 2021 12:13 am
The narrow ones are fine for wire type wheels with drop centers. They are there to protect the tube from any ruff areas over/around where the spokes were welded to the fellow.
Posted: Tue Oct 05, 2021 7:15 am
by Humblej
Narrow rubber band liner for wires, wide flaps for demountable rims.
Posted: Tue Oct 05, 2021 7:43 am
by TWrenn
Gorilla tape will do the same thing for a lot less money!
I use it on all my wheels, no flaps, no problems either. JMHO
Posted: Tue Oct 05, 2021 7:19 pm
by Humblej
Bruce, What wheels do you have?
Posted: Tue Oct 05, 2021 7:56 pm
by BLB27
Jef, Mine are wire wheels.
Posted: Fri Oct 08, 2021 9:02 am
Use narrow rim strips in your wire wheels, the rubber strip protects the tube where it rides in the drop center. That area has the weld joints of the spokes that can rub and wreck a tube.
Never use a flap in Ford welded spoke drop center rims. If a flap is used, the tire casing can’t be squeezed into the drop center, and if installed, later removal of the tire is near impossible due to that thick flap!
IMO, refrain from duck tape, it will decompose over time and shed into plastic fiber mess. Have cleaned up lots of that stuff from clincher rims too.
