Model T aluminum locking steering wheel
Tmodelt
First Name: Kim
Last Name: Wynn
Post by Tmodelt » Sat Mar 23, 2019 7:33 pm
All thoughts / ideas welcome. The aluminum spider has been painted white with what looks like house paint. The rim will be replaced. What would be the easiest / fastest way to remove this paint without affecting the locking mechanism? I don't plan on polishing. Thanks
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: Model T aluminum locking steering wheel
Post by Henry K. Lee » Sat Mar 23, 2019 7:57 pm
Kim if you have a turkey fryer and a large pot with hot water does an amazing job!
Tmodelt
First Name: Kim
Last Name: Wynn
Post by Tmodelt » Sat Mar 23, 2019 8:27 pm
Should I turn the heat on under the fryer to keep water hot? Just got 2 new keys cut. The locksmith made sure lock and key worked.
