Rust arount head bolts and in sparkplug wells
Topic author - Posts: 163
- Last Name: Schroeder
- * REQUIRED* Type and Year of Model Ts owned: 1916 Touring
- MTFCA Number: 50300
- MTFCI Number: 87
Can anyone tell me what's going on with my engine? Thers is new rust around several of the new head bolts. I saw water bubbling up in the sparkplug wells on 3 & 4. Is my head cracked?
1916 Touring
- Last Name: Humble
- * REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
- MTFCA Number: 28034
Re: Rust arount head bolts and in sparkplug wells
I would suspect a leaking head gasket.
- MTFCA Number: 52564
Are you seeing water or just compression blow by in the spark plug holes?
1920 Dodge touring
1920 Dodge touring
Water from rain/car washing will drain into the wells around the spark plugs. That moisture will also create rust where the headbolts have removed paint as they are tensioned. As indicated, compression blowby at the plugs is common, usually bubbling in oil, but just as usual if there is water in the plug wells.
There may be absolutely nothing wrong/worth fixing.
- Last Name: Noonan
- * REQUIRED* Type and Year of Model Ts owned: 1925 Runabout
Jeff, i would think that if you don't actually see water seeping up from the head bolts, you're probably fine. Judging from your pic it seems like tightening the head bolts just scraped off what finish you had on the head, and the little wells surrounding the bolts just accumulated water, allowing it to rust. Like Mark mentioned, its pretty common on T's to get some blow by at the spark plugs and some here have added products to the plug to keep it from leaking. Good luck.
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
- MTFCA Number: 24868
Your photo does not suggest any real problem. As someone else stated, car washes can easily do what you describe. Just keep an eye on things.
- MTFCI Number: 87
Thank you everyone.
I just replaced the head gasket (w/copper spray) and double checked the ft lbs. (55) after a few heat-cool cycles.
I noticed the water !after! I washed the car. duh.
I'm gonna test drive it and I'll see how the power feels.
1916 Touring
- MTFCA Number: 14972
- MTFCI Number: 15411
Be careful pulling 55 lbs. !
- First Name: Erik
- Last Name: Barrett
The spark plugs are pipe thread. Use some pipe thread sealant on them.
- MTFCI Number: 87
Won't that risk debris falling into the combustion chamber when I remove them?
1916 Touring
- First Name: Joseph
- Last Name: Andulics
- MTFCA Number: 9766
My choice of what to use on the spark plugs. Enjoy
https://www.permatex.com/products/lubri ... lubricant/
Re Won't that risk debris falling into;
A; No not really, it's just a thin coat. Even if it did, it would blow out the exhaust when the engine fired.
B; I have been using white teflon tape for years with no issue. One or two layers is all that is needed. The threads cut thru and have never had a firing issue. Some use aluminum foil.
1920 Dodge touring
1920 Dodge touring
One might consider blowing the wells out with air prior to removal !
- First Name: Michael
- Last Name: Pawelek
[quote=Jeff5015 post_id=19084 time=1553556321 user_id=1008]
Thank you everyone.
[/quote]
When I wash any Model T or Model A I drape a large plastic garbage bag across the top of the engine so nothing gets wet. This is assuming a cold engine!
Thank you everyone.
[/quote]
