Spots On Headlight Rims….
Posted: Thu Oct 07, 2021 6:24 pm
by MichaelPawelek
I have no clue whether these rims are nickel or chrome plated. How does one remove the tiny spots in the plating? Would it be best to use a cloth wheel with rouge and then seal with wax or is there a better option. Will decide what to do more permanently later on …
Re: Spots On Headlight Rims….
Posted: Thu Oct 07, 2021 7:28 pm
By colour, they look to be nickel plated. The spots may be the beginning of the breakdown of the plating if they are brass rims. Any polishing will be cosmetic, giving a temporary improvement until the breakdown resumes. I would hand polish them, using Autosol paste. You may have your own favourite. The final answer is to have them replated with new nickel.
Posted: Fri Oct 08, 2021 10:01 am
by ModelTWoods
Michael, since the previous owner CONVERTED the 25 to look like a 26-27, why not paint all plated surfaces black, and return it to original, eliminating the problem of plating deterioration? BTW, what's the verdict on the white wall tires?
