Differentials
Posted: Fri Oct 08, 2021 3:31 pm
by jeffstag
What is the difference in these differentials ?
Re: Differentials
Posted: Fri Oct 08, 2021 3:35 pm
Flip em over. One probably has the long thru bolts (left?). The other studs?
Re: Differentials
Posted: Fri Oct 08, 2021 3:39 pm
by jeffstag
Correct
Re: Differentials
Posted: Fri Oct 08, 2021 3:40 pm
by jeffstag
But what does that mean in terms of yeas used?
Re: Differentials
Posted: Fri Oct 08, 2021 3:43 pm
I prefer the security of the thru bolt style. If you use the stud type, the wire nuts together, no cotter pins.
Re: Differentials
Posted: Fri Oct 08, 2021 3:45 pm
Left is later style. Dont know the year they changed off the top. A trip to McCally will be in order.
Re: Differentials
Posted: Fri Oct 08, 2021 4:05 pm
by DHort
The one on the left has grooves cut in the top and the spider gear appears to be out of alignment.
Re: Differentials
Posted: Fri Oct 08, 2021 4:18 pm
by jeffstag
I have several with those grooves. If we’re looking at the same thing those are supposed to be there. Here’s another one with the grooves
Re: Differentials
Posted: Fri Oct 08, 2021 4:22 pm
by jeffstag
It looks like I can mix and match the different styles of differential halves. I can used the bottom half with the thru bolts, and then go with a top half with or without grooves. Both look good in terms of wear.
Re: Differentials
Posted: Fri Oct 08, 2021 4:40 pm
I have switched tops. The axle gear hole is/was originally 1.812" Measure them, to know for sure.
A best guess on the stud type usage is 14-20,21. The first gen after the 1.807" axle gears.
