Valve Spring Seat Diameter
Posted: Sun Mar 24, 2019 12:17 pm
by mortier
Could some tell me the Model T Valve Spring Seat diameter?
Phil
Re: Valve Spring Seat Diameter
Posted: Sun Mar 24, 2019 1:08 pm
by Mark Gregush
Outer 1.125 inner 1.025 approx. Material approx .035 thick
The is from a used one so may have some wear. The inner would just be larger then the spring diameter.
Posted: Sun Mar 24, 2019 7:53 pm
by mortier
Thanks. I'm hoping it will fit my 1915 Overland.
Phil
Posted: Sun Mar 24, 2019 8:04 pm
by Mark Gregush
Another choice might be Chevrolet. Up to 1928 at least they used a flattened cotter pin type pin. So the seat would work somewhat the same as Ford and would be a little larger. I will check the diameter of the spring later today and post the info.
Posted: Sun Mar 24, 2019 9:49 pm
by Mark Gregush
The Chevrolet (1928) springs are approx. 1.200 in diameter. Subtract about 3/16 for the inside diameter. The other difference is the Chevrolet keepers don't have an outer rim, like the Ford ones. If you look close at the photos in the link you can see them.
http://my28chev.blogspot.com/2012/06/19 ... -rust.html
Posted: Sun Mar 24, 2019 10:19 pm
by Henry K. Lee
Phillip if you need the 1928 Chevy ones I have plenty of serviceable ones.
All the Best,
Hank
