Has onyone found an online store that sells the glass tape at a reasonable price and will ship to Australia? I just can't afford a new magneto at the moment on top of everything else.
Thanks guys.
Shawn
Glass tape
Topic author - Posts: 89
- First Name: Shawn
- Last Name: Barnard
- * REQUIRED* Type and Year of Model Ts owned: 1926 coupe
- MTFCA Number: 52564
Re: Glass tape
Might start by doing a search "mtfca rebuilding magneto" There have been recent post that should have companies and suggestions for getting the tape.
Also so, edit your title. When I saw it, was thinking glass setting tape, not wrapping the coils on the magneto. That should help get more views. Click on the pencil, that will open the edit window.
1920 Dodge touring
1920 Dodge touring
- First Name: Mario
- Last Name: Brossard
- MTFCA Number: 30981
- MTFCI Number: 30981
Re: Glass tape
I don’t know how much your tape is broken? If it’s some magneto, you could use transparent epoxy as well. I did Personally To fixe an issue with 2 round magneto and it’s work properly.
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: Shawn
Re: Glass tape
It's pretty bad. I don't think I would trust it.
Re: Glass tape
I did a search on Scotch 27 tape in AU and found a supplier of Glass Tape in AU. However , their web site may have an issue so contact via email sales@embossingtapesupplies.com.au
ETS
Miranda NSW 2228 Australia.
Telephone: (02) 9526 2055
Facsimile: (02) 9524 7371
ETS
- First Name: Neil
- Last Name: Martin
- * REQUIRED* Type and Year of Model Ts owned: 11 tourer 18 tourer 18 TT
Re: Glass tape
Shawn,
You don't need glass tape for bobbin plate repairs, I have repaired many > 30 volt AC Model T bobbin plates and rewound and taped thousands of >240 volt AC coils using linen tape. The important item is the insulating varnish used to secure the coils from vibrating. Where are you in VIC ? Send it over the boarder and I will fix it for you ......n
