Need Soldering Advice…
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Thu Oct 14, 2021 7:22 am
I am going to make a longer tubular filter screen for a gas tank and have not soldered for many years. I see one can buy small sheets of stainless steel screen. Are there not two types of solder? What would be the correct type to use on SS or does it matter? Any other advice appreciated. Thanks…
MTFCA Number: 4838
MTFCI Number: 115
Re: Need Soldering Advice…
Post by DanTreace » Thu Oct 14, 2021 8:21 am
Why not use what was original? Easy to procure brass mesh, #100 is the size for fuel filter.
Have done that for under tank potato screens, and to replace the barrel screen in the 26-27 cowl bowl too. Ordered a sheet from Restoration Supply co.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Thu Oct 14, 2021 8:57 am
This tank still has a tiny bit of debris inside and the horizontal opening to the potato can be plugged as the fuel flows down. It already has a vertical screen above the potato that needs replacement. Dual filtering!😊
Just using viable options until I get this tank under control or replaced so I can work on the engine and transmission.
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Thu Oct 14, 2021 9:16 am
With that under seat tank, you can buy that accessory cylinder screen that solders to the upper inlet of the potato, Lang's has new for $8 .25
Part# 2903BSC. About cheaper than ordering brass screen mesh and forming the same and soldering there, IMO.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Thu Oct 14, 2021 9:27 am
Wow, Thanks Dan. I had no idea that part was available…
MTFCA Number: 51486
Post by TXGOAT2 » Thu Oct 14, 2021 9:40 am
I don't believe you can solder stainless steel.
jab35
Last Name: Bartsch
MTFCA Number: 30615
Post by jab35 » Thu Oct 14, 2021 9:47 am
You use silver solder for SSteel. Tricky job b/c of higher temps and fine screen. Soft solder and the lang's part is a better solution in my view. jb
Philip
First Name: Philip
Last Name: Thompson
* REQUIRED* Type and Year of Model Ts owned: 1924 touring
Post by Philip » Thu Oct 14, 2021 10:18 am
you can solder it but you must tin it with an iron first
Craig Leach
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Thu Oct 14, 2021 11:39 am
Fold the ends of the screen over so they will not unravel. Wrap it around a propper size mandral, lay the solder ( 50/50 1/16" works good ) between the layers of screen and lightly tap with a small hammer forcing the solder through the screen. do the same with end. push the screen into the fitting and secure with a drop or two of JB. But if you can get the 2903BSC from lang's thats done for you. I for one didn't know that was available. Thats what the Forum is for.
Craig.
Post by Allan » Thu Oct 14, 2021 9:35 pm
I believe stainless steel requires silver soldering. The higher temperatures required for silver soldering are very difficult to control when using wire mesh. Brass mesh and soft solder are far easier to work with. Getting the brass mesh to hold the shape you require is made a lot easier if you cut the mesh on the flat and solder the edges. Then the solder will hold the shape you wish the mesh to take, at the same time keeping the wires forming the mesh under control.
