You may be addicted to Model T fords when…..
Posted: Thu Oct 14, 2021 10:56 am
by Thorlick
all you notice is the wrong rear windows!
Wrong rear windows
Wrong rear windows
Re: You may be addicted to Model T fords when…..
Posted: Thu Oct 14, 2021 2:07 pm
by Dan Hatch
Maybe not. Isn’t that a Canadian car?
Posted: Thu Oct 14, 2021 2:39 pm
by JohnM
When you can watch and sit through all of Scott C's socially distancing videos. :D
Posted: Thu Oct 14, 2021 3:01 pm
by Don D
you are near a bee hive and look around for a running "T" :-)
Posted: Thu Oct 14, 2021 8:34 pm
by Wayne Sheldon
Windshield indicates that it is a Canadian car. Lower pane is hinged. Canadian slanted could be as early as 1920. Canadian slanted windshield that early could also have a one man top, and two oval rear lites were used on many Canadian tops.
What I want to know is why are the sidelamps mounted at different heights? One is slightly above the cowl bead, the other is slightly below the cowl bead.
Posted: Thu Oct 14, 2021 8:49 pm
Wayne, you are suffering from an optical delusion! :D If you put a straight edge beween the tops of the two lamps you will have a line perfectly parallel to the bottom of the windscreen.
Posted: Thu Oct 14, 2021 9:44 pm
by JTT3
What really gives it away is the drivers side front door is hinged!
Posted: Thu Oct 14, 2021 9:53 pm
by TonyB
Ooops I put this in the wrong thread.
Sorry. TonyB
Posted: Fri Oct 15, 2021 2:02 am
by david_dewey
Hmm, what I notice is the glass-cased electric meter on the building behind the car, and the modern sidewalk joints. There's probably more stuff, but that's what jumps out at me.
Posted: Fri Oct 15, 2021 3:52 am
by marctee
That T makes the neighborhood looks even nicer !
Posted: Fri Oct 15, 2021 7:16 am
by Humblej
...when the T gets a parking spot in the garage and the wifes new car is parked outside.
Posted: Sat Oct 16, 2021 2:19 pm
by Quickm007
That's the actual case of my wife... :lol:
Posted: Sat Oct 16, 2021 3:52 pm
by Will Brown
The aluminum gutter is another discrepancy. It is obviously meant to be a Candian T as it has an Ontario license plate.
Posted: Sat Oct 16, 2021 4:13 pm
I wonder if the driver is aiming at the man walking behind him or someone else?
Posted: Sat Oct 16, 2021 4:14 pm
Posted: Mon Oct 18, 2021 3:07 pm
by tmodeldriver
Only in the USA do we park cars worth tens of thousands of dollars out in the weather and fill our garages up with worthless junk. :roll:
