***1918-1822 Model TT Ruckstell Axle Differential Assembly**
Posted: Thu Oct 14, 2021 4:34 pm
by VowellArt
Does anybody know which part number go to which set of nuts? There is no description of where those two part numbers go....other than a rather muddy picture of no particular scale.
Also were the screws that held the differential housings together lock wired also?
Re: ***1918-1822 Model TT Ruckstell Axle Differential Assembly**
Posted: Fri Oct 15, 2021 4:16 am
by A Whiteman
Can't help with the numbers, but it is looking good!
The carrier for the 2 pinion shaft looks about right,
Cheers
Adrian
Posted: Sun Oct 17, 2021 11:13 am
by L.I. Tom
On these truck axle's does both axles use the ball bearing or only the rux side (I don't have the book but the fella that owns it does but I haven't looked at it yet). I thought I saw a video a while back were the original passenger side used an original bearing and thrust washer. If so does anyone know if those thrust washers available anywhere? I will be going over one of these this winter. Thank you for creating these beautiful breakdowns.
Tom
Posted: Sun Oct 17, 2021 7:51 pm
by VowellArt
Tom, both sides have same Thrust Bearing P-1009.
Posted: Sun Oct 17, 2021 11:21 pm
by L.I. Tom
Thank you very much for the reply and the photo.
Tom
