Bow wrapping
351cmach
Last Name: Durgin
MTFCA Number: 32430
MTFCI Number: 25880
Board Member Since: 2014
Bow wrapping
Post by 351cmach » Mon Oct 18, 2021 5:27 pm
I'm working on replacing the top on my 26 Roadster pick up. I've spent hours searching this site and the web but can't seem to find a clear answer. How are the bows wrapped? On a 45 almost like you wrap a candy cane or length wise along the bow? Is the front bow wrapped like the other bows? Also how far down do you wrap the irons? I'm assuming down around the curve.
flatbroke3
First Name: harold
Last Name: musolf
* REQUIRED* Type and Year of Model Ts owned: 1911 touring 1926 touring 1913 touring
MTFCA Number: 51354
Board Member Since: 2010
Re: Bow wrapping
Post by flatbroke3 » Mon Oct 18, 2021 5:39 pm
on the bias..i.e. at a 45 degree angle...that is, cut the fabric on a bias, then rap the bow.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Re: Bow wrapping
Post by CudaMan » Mon Oct 18, 2021 5:42 pm
As you said, the bow wrap is cut on the bias (45 degrees). This gives it the flexibility to conform to the bends in the corners.
Here is a video showing how Elizabeth at "Class it Up" does it:
https://www.youtube.com/watch?v=h6Y8gKaKIrs&t=27s
351cmach
Last Name: Durgin
MTFCA Number: 32430
MTFCI Number: 25880
Re: Bow wrapping
Post by 351cmach » Mon Oct 18, 2021 8:11 pm
She is wrapping it lengthwise. Is that the correct way?
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Re: Bow wrapping
Post by CudaMan » Mon Oct 18, 2021 8:23 pm
Yes. Put the seam on top so that it can't be seen inside the car. :)
Do you understand what it means for the fabric to be cut on the bias? It means the threads run 45 degrees to the length of the bow wrap, like this:
351cmach
Last Name: Durgin
MTFCA Number: 32430
MTFCI Number: 25880
Re: Bow wrapping
Post by 351cmach » Mon Oct 18, 2021 8:43 pm
Yes I understand what it means to cut on the bias but that doesn't answer my question..
MTFCA Number: 24868
Re: Bow wrapping
Post by Jerry VanOoteghem » Mon Oct 18, 2021 8:49 pm
Yes
Re: Bow wrapping
Post by Scott_Conger » Mon Oct 18, 2021 8:53 pm
One has to ask, after watching the video of a professional top/interior manufacturer/installer plying her trade: why would you ask "is that the correct way?"
Robert...it is the right way, and every question you have asked is filmed and described in detail
NH Full Flow Float Valves
George Mills
Last Name: Mills
MTFCA Number: 29497
MTFCI Number: 10032
Re: Bow wrapping
Post by George Mills » Mon Oct 18, 2021 8:56 pm
FWIW...I wrap it like a candy cane about a 2/3 exposure. I also fold the live edge under about 1/4 inch to give me a fold instead of a live edge. I come around the curve taut with really no change is exposure, and then get tricky by cutting a bit of a duckbill and pushing it up under to give a squared edge look. I think the snap screw then holds that all together from unraveling. (I'm thinking on some I have driven a tack to hold the fold under tight and square, but its been a bit, and I use tacks driven half way along the top to make all my wrap tensions work and if it balks and wants to 'gather' I don't lose the whole game...just back to a previous pin that I'm happy with. I then pull the tacks when done and if you are gentle enough, you can just watch the tack hole disappear.
I'm sure others do it differently.
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Re: Bow wrapping
Post by Oldav8tor » Mon Oct 18, 2021 9:01 pm
Here's a link on wrapping the front bow which on many T's is wrapped in vinyl <https://mtfca.com/phpBB3/viewtopic.php?f=2&t=14323> On my 1917 the wood bows make a 90 degree curve before joining the steel sockets. I carried the wrap to just below the top of the sockets.
MTFCA Number: 121
MTFCI Number: 16310
Re: Bow wrapping
Post by Original Smith » Tue Oct 19, 2021 10:04 am
For the pads and all bows in back of the front one, it's called bow drill.
SteveBoothroyd
First Name: Steven
Last Name: Boothroyd
* REQUIRED* Type and Year of Model Ts owned: US built 1922 touring
Re: Bow wrapping
Post by SteveBoothroyd » Mon Oct 25, 2021 2:23 am
After I wrapped the bows, I sprayed a fine mist of water on them, then used my wife's hairdryer to dry them off; in the process, most wrinkles disappear.
Regards,
Steve Boothroyd
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Re: Bow wrapping
Post by Oldav8tor » Mon Oct 25, 2021 11:03 am
My wife sewed the cloth material (cut on the bias) into a long tube and then pulled it inside-out so the cut edge was to the inside. I then pulled it onto the bow, sprayed it with warm water and pulled it taut, securing the ends temporarily with tie wraps. Finishing with a hair dryer while it was still damp, it snugged up wrinkle free.
For the vinyl, I did it in three sections. The two curved ends and the straight center (see previous post). I used contact cement and tacks (sparingly) to attach it.
Once the bows are finished you have the top to install. A whole other story :D Do a forum or google search and you'll find lots of information.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Re: Bow wrapping
Post by CudaMan » Mon Oct 25, 2021 11:30 am
I like the tube sock idea, I may try that next time! :)
