Transmission clutch Gap tool
Topic author - Posts: 987
- Last Name: Gould
The vendors are out of the gap tool I needed, so I tried using the correct size socket. It didn't work well so I made one out of stuff I had on hand. I decided to thread the plug and handle because my welding/brazing/soldering skills are marginal. I'm happy with the result.
- MTFCA Number: 30701
- MTFCI Number: 24033
Re: Transmission clutch Gap tool
Nice work. How's that saying..."necessity is the cause of invention" or something like that!
I don't have that kind of patience. Well done. I used a modern Ford wheel nut, 13/16" across the flats with a rod welded to it for a handle. I like the fact that the flats on the nut set the tool well, rather than having to organise it to sit at the correct angle in the gap.
Allan from down.
Allan from down.
- Last Name: Bartsch
- MTFCA Number: 30615
Nice project. Following on Alan's point, it seems making the gage like RGould's from 13/16" round stock and using the diameter of the cylinder as the gage would work too.
I've never seen a tool like that. Looks like a very small mallet. Where and for what purpose is it used?
- MTFCA Number: 14972
- MTFCI Number: 15411
It's used to set the distance between the driving plate and the clutch throw-out collar.
Used to adjust the clutch fingers http://www.mtfca.com/discus/messages/59 ... 1474933793Norman Kling wrote: ↑Sat Oct 23, 2021 10:42 amI've never seen a tool like that. Looks like a very small mallet. Where and for what purpose is it used?
- Attachments
- Clutch gap tool.png (661.91 KiB) Viewed 1396 times
Thank you,
I learned something this morning.
- First Name: Anthonie
- Last Name: Boer
- MTFCA Number: 19790
I use this , Electric wire
Toon
