nh straight through
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
MTFCA Number: 17946
MTFCI Number: 15366
nh straight through
Post by Don ellis » Thu Oct 21, 2021 7:23 pm
How do you tell the difference between a sway back and a straight thru carb float? I saw something about a difference, I want to make sure mines correct.
Kerry
Last Name: van Ekeren
Re: nh straight through
Post by Kerry » Thu Oct 21, 2021 7:30 pm
Same float for both.
Moxie26
Last Name: Jablonski
MTFCA Number: 407
Post by Moxie26 » Thu Oct 21, 2021 7:42 pm
Don;... I've used the same NH float in straight through and humpback casting carbs with no problem
Don ellis
First Name: Don
Last Name: Ellis
MTFCA Number: 17946
MTFCI Number: 15366
Post by Don ellis » Fri Oct 22, 2021 4:18 pm
I know i have too but I ran across a part Langs sells for the straight thru float, a hinge. I wasn't aware of a difference. Part number 6201NHS, kinda pricey too.
