Source for miscellanious Domed Bolts
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Fri Oct 22, 2021 11:58 am
Other than cylinder head DOMED BOLTS, does anyone know of a source for misc. sized domed bolts, like the ones supplied with Stromberg carburetors to mount them to the intake manifold? I have a Stromberg M-1 carb that didn't come with the bolts and they look to be smaller in diameter than the bolts furnished with an OF. I haven't checked with McMaster-Carr, but I doubt they have any.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: Source for miscellanious Domed Bolts
Post by Henry K. Lee » Fri Oct 22, 2021 12:42 pm
Terry if you can give me length and sizes required.., I might have some in my bins.
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Fri Oct 22, 2021 2:26 pm
Thanks, Hank. I'll measure and get back to you.
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Fri Oct 22, 2021 3:27 pm
If you can't find them, I use Allan socket head bolts to mount my carbs.
1920 Dodge touring
Post by Scott_Conger » Fri Oct 22, 2021 3:53 pm
If Hank does not have them, you'll want to consider something else, as they are a custom fabrication these days...not a stock part
NH Full Flow Float Valves
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Fri Oct 22, 2021 4:14 pm
Hank: 5/16" diameter x 1/2"-3/4" length (1" would even be OK; I'd just cut to length) 18 T.P.I. Need 2.
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Fri Oct 22, 2021 4:22 pm
ring gear bolts. Period correct, tall head. Safety wire for a cool detail. Can weld the holes up & round the heads also.
Post by TRDxB2 » Fri Oct 22, 2021 5:18 pm
Don't know the sizes but Lang's has domed bolts for the Water Outlet and also for the front spring clip
https://www.modeltford.com/pl.aspx?t=s& ... Bts&page=1
Post by Allan » Fri Oct 22, 2021 6:42 pm
My OF came with hex head bolts, with slots for a screwdriver, and were coarse thread. I lost one!!!!
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Fri Oct 22, 2021 7:53 pm
Email sent Terry.
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Sat Oct 23, 2021 10:50 am
This bolt sounds like the same hardware to hold the carburator on a harley knucklehead. 5/16 nc, slight round head, slot. Colony mfg.
jiminbartow
Last Name: Patrick
MTFCA Number: 50126
Post by jiminbartow » Sat Oct 23, 2021 11:25 am
Try www.McMaster.com. Enter. “Dome-head bolts” (don’t forget the dash). They might have something you can use or give you ideas on something else that might work. Jim Patrick
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Sat Oct 23, 2021 11:51 am
Nice set sent this morning!
