Aluminum Step Plates…
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Sun Oct 24, 2021 6:39 pm
After polishing aluminum step plates is there any sealer that can be used to slow down oxidation? I realize this is a losing proposition since stepping on them constantly will wear off a coating but slowing the oxidation would be a start! Thanks….
Nunsio1
Last Name: Monticciolo
* REQUIRED* Type and Year of Model Ts owned: 1924 C Cab truck
MTFCA Number: 21108
Re: Aluminum Step Plates…
Post by Nunsio1 » Sun Oct 24, 2021 7:52 pm
Try Semichrome polish, old & trusted product and leaves a protective coating to slow oxidation. I believe it’s in Lang’s catalog.
John
Oscoda Michigan
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Sun Oct 24, 2021 9:06 pm
Michael, Brass musical instruments are clear lacquered to prevent tarnishing. I suppose it might be possible to step into that coupe without stepping on the step plate.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Sun Oct 24, 2021 9:34 pm
True Terry but this is not a garage queen. I feel silly already asking my original question since the step plate is a step plate! 😊
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
MTFCA Number: 50618
Post by Jeepbone1 » Sun Oct 24, 2021 11:44 pm
Go to your local monument maker. You know, they guys who make head stones. Ask them for a can of the sealer they use for their bronze markers. Some cemetery grounds keepers keep some too.
I worked in an instrument repair shop out of high school. I wouldn’t use instrument lacquer. It’s great for hand use generally but if you start stepping on it it’ll start chipping. It also turns yellow pretty quickly. Not so noticeable on brass instruments but it happens. Also one of the reasons you don’t see silver plated instruments lacquered.
Brad
