Time saver
yerffej
First Name: jeffrey
Last Name: delancey
* REQUIRED* Type and Year of Model Ts owned: 1919 Runabout
Time saver
Post by yerffej » Tue Oct 26, 2021 10:01 pm
Can I use time saver on the rods while engine is in the car?
Last Name: Humble
* REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
MTFCA Number: 28034
Board Member Since: 2006
Re: Time saver
Post by Humblej » Tue Oct 26, 2021 10:53 pm
Yes, I have done it with a 4 dip oil pan.
MTFCA Number: 14383
Re: Time saver
Post by speedytinc » Wed Oct 27, 2021 9:09 am
Sure. Keep it wet. You can really make a mess of the job if the stuff gets dry & leaves hard deposits in the babbit.
yerffej
First Name: jeffrey
Last Name: delancey
Re: Time saver
Post by yerffej » Wed Oct 27, 2021 11:58 am
Would you please tell me the process. Thanks
MTFCA Number: 24868
Re: Time saver
Post by Jerry VanOoteghem » Wed Oct 27, 2021 3:25 pm
Time Saver comes with directions on how to use it.
https://www.newmantools.com/lapping/time.htm#use
https://www.newmantools.com/lapping/tim ... ooklet.pdf
RGould1910
Last Name: Gould
Re: Time saver
Post by RGould1910 » Wed Oct 27, 2021 5:53 pm
I've noticed that time-saver when used to create clearance on rod bearings can dry out when the rods are spun by hand on a crank outside the car . If you did it in the car, you'd have to do 1 bearing at a time and run the engine about 20 seconds then remove the cap and add oil to the bearing surface. I know the directions say you can leave it on the bearing because it disintegrates but my experience is you have to clean it up afterwards. It's pretty messy and I wouldn't trust Fords splash lubrication to do that.
Re: Time saver
Post by Scott_Conger » Wed Oct 27, 2021 6:09 pm
It can be done just fine by hand by swinging the rod (upside down) within in the limited confines of the crank case by occasionally rotating the crank 90 degrees for each time the rod is assembled. If you will properly and accurately measure the crank and call one of the rod suppliers with the .xxxx size of the crank, they will bore one to the correct (+.0015") size and it will lap in almost immediately or within the removal of a single shim. Do NOT try to order a standard or simple .010" oversize rod from the retailer, or you will spend the rest of your natural life laying on your back.
I just coached a friend through this operation via email a couple of months ago. He is on the other side of the continent and had only a week between tours to learn/try/succeed on this process. Several tours have subsequently gone very well.
Anyone can do it.
NH Full Flow Float Valves
