Ford NH float for Improved Car
Posted: Wed Oct 27, 2021 1:56 pm
I have a '26 Runabout. The Ford NH in my car appears to have a casting that was made in 1925. That is based on what I've seen in the Encyclopedia. That means it was in a car without a cowl-mounted gas tank. Having read that later Holley NH carbs have larger floats for improved cars, I would like to find a correct float, if I don't already have one. This is my NH.
I found the photo below on the old forum that, presumably, shows the Holley floats.
Can anyone tell me what the height of an improved car float should be? Are Holley and Ford NH floats interchangeable?
Another stupid question is about the mixture adjustment. My needle turns by itself due to vibration when I increase the rpm. Should I add clamping pressure (friction) to the fingers by pinching them? Is there another, proper, way to do it?
